sgalland
Post
by sgalland » Thu Jul 10, 2008 11:49 pm
I packaged the 1.3.0 3DxWare driver for Ubuntu/Debian Linux distributions.
I also add several additional tools that enhance the usability of the driver:
- - the 3DxWae daemon is not automatically launch at startup but when the user decide to use it
- a set of desktop commands are provided to start/stop the daemon
- a Gnome2 notification applet permits to show the running state of the 3DxWare daemon and to start/stop it with a single click
This package is available as '3dxware' on my package repository:
http://www.arakhne.org/spip.php?article51
Of course you are welcome to give me feedback
Stephane
Dr. Stephane GALLAND
Systems and Transport Lab.
colezero
Post
by colezero » Sat Jul 12, 2008 4:19 am
This sounds great and i installed it with apt. But how to use this? Is there any documentation available? Or could you tell me on hoe to use it?
colezero
Post
by colezero » Sat Jul 12, 2008 6:25 am
Ok i figured out how this works, with 3dxmanager start etc.
But the gnome-applet doesn't work, due this error:
Can't locate Gtk2/TrayIcon.pm in @INC (@INC contains: /etc/perl /usr/local/lib/perl/5.8.8 /usr/local/share/perl/5.8.8 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.8 /usr/share/perl/5.8 /usr/local/lib/site_perl .) at /usr/bin/g3dxapplet line 29.
BEGIN failed--compilation aborted at /usr/bin/g3dxapplet line 29.
sgalland
Post
by sgalland » Sat Jul 12, 2008 6:26 am
First be sure that you have installed the version 1.3.0-0arakhne5 which is much more robust.
With this package, you have three way to launch the 3DxWare driver:
1) use one of the command lines:
3dxmanager start (to start the driver)
3dxmanager stop (to stop the driver)
3dxmanager quit (to stop the deamon, need administrator to start again)
2) Launch Gnome2 applet: g3dxapplet
3) Use one of the programs in the Application menus (section 'System Tools')
Of course, before using the 3Dx driver, you must launch the "3dxactivator" as an administrator (it should be done during the package installation) with the command line:
sudo /etc/init.d/3dxware start
Regards,
Stéphane
sgalland
Post
by sgalland » Sat Jul 12, 2008 6:34 am
Sorry, I forget one package dependency.
Now I released the version 1.3.0-0arakhne5.1 which force to forgotten package.
Stéphane
colezero wrote:Ok i figured out how this works, with 3dxmanager start etc.
colezero
Post
by colezero » Sat Jul 12, 2008 11:58 am
Ah now it works flawlessly, thank you for this package and for you work.
The only thing i am now facing is this annoying configuration window of the driver.
It would be great if this could also be minimized to the gnome panel or at least to be closed.
greetings
sgalland
Post
by sgalland » Sat Jul 12, 2008 3:25 pm
colezero wrote:Ah now it works flawlessly, thank you for this package and for you work.
greetings
This is also annoying for me. I'm thinking that closing this configuration window is not possible. According to several other topics, we could only minimize it. I'm planning to write an other command that permits to view/hide the configuration windows...but it is a more complex job than packaging the driver.
Stéphane.
colezero
Post
by colezero » Sun Jul 13, 2008 7:22 am
Are the linux sources for the driver available? I mean is the driver open source?
If not 3dconnexion should think about it, so that the community may be able to improve some things.
Anyway it would definitely cool, if you could do something to hide/iconify it.
I wish you good luck for this.
Greetings
sgalland
Post
by sgalland » Mon Jul 14, 2008 2:16 am
colezero wrote:Are the linux sources for the driver available? I mean is the driver open source?
Greetings
No, the source code is not open. So I'm needing to find some hook to avoid the window displaying. I'm not sure it is easy to be done but I will try.
Stéphane.
colezero
Post
by colezero » Tue Jul 15, 2008 9:31 am
Well i guess this is the 'easiest' way, but also a little 'dirty'.
Please 3DConnexion Developers, put the Unix/Linux Driver into 'Open Source' - state.
This would definitely worth it.
So many users could contribute new versions and refinements and, what i think is the most importend, learn from it.
We could make a better Linux integration, especially for the desktop environments like kde or gnome. I mean, i will not say that the driver gui looks a bit oldskool, but i will.
Please think about it. There are many reasons for releasing the source of the driver, especially for linux.
sgalland
Post
by sgalland » Mon Jul 21, 2008 1:44 pm
I'm also providing a development API for C++ and Java.
See
this forum for discussion.
Stéphane
jgeling
Post
by jgeling » Thu Jul 24, 2008 1:51 pm
Nice work. Thanks,
I have installed your package on kubuntu hardy. The driver starts with the manager and de applet. But the gnome applet g3dxapplet runs with an average of 50% cpu on the dell inspiron 6400 (a dual core system)
This is under KDE3, haven't tried it on gnome desktop.
Johnny
colezero
Post
by colezero » Fri Jul 25, 2008 2:06 pm
Jeeez!! Same here on single core, but with an usage of 95%!!!
Holy i didn't noticed it.
colezero
Post
by colezero » Sat Jul 26, 2008 5:24 am
Does you thread uses a while-loop?
Something like:
while(!terminate) {
DoSomething();
If so, you need to add a little Sleep in the beginning of the loop, about 250ms for example.
This would reduce the cpu-usage!
sgalland
Post
by sgalland » Mon Jul 28, 2008 4:21 pm
I published new release of the gnome applet.
It include a call to yield into the main loop.
Please notify me if the processos consumption is still too high. It should consume processor has much as possible but leave enough resources to the other processes.
If not, I will put a sleep() call in place of yield().
Stéphane
colezero wrote:Does you thread uses a while-loop?
Something like:
while(!terminate) {
DoSomething();
