Failed to get User error.
demaseme
Post by demaseme » Mon Nov 20, 2017 12:55 pm
Hello, I've been trying to install an Space Navigator driver on both Ubuntu 17.10 and Tumbleweed (Open SUSE) without any results.
I followed the instructions on the text file from the file that I downloaded from your official website and make some digging on google but I can't seem to fix my problem, on the main installation I get this error:
[2017-11-20 13:50:51] Error: 3dxsrv.c :: startupCommandLine(), authGetUser(), failed to get user
However, I try to run the driver :
demaseme@localhost:/> /etc/3DxWare/daemon/3dxsrv -d USB
[2017-11-20 13:53:07] Error: 3dxsrv.c :: startupCommandLine(), authGetUser(), failed to get user
Now with sudo:
demaseme@localhost:/> sudo /etc/3DxWare/daemon/3dxsrv -d USB
[2017-11-20 13:53:51] Error: 3dxsrv.c :: startupCommandLine(), authGetUser(), failed to get user
I've been trying for about 2 weeks now and now I'm really tired to keep looking, I need to get it running for a homework for this week. Can anybody help me? I get the same error in Ubuntu, currently my laptop has Tumbleweed installed. Thanks.
demaseme
Re: Failed to get User error.
Post by demaseme » Mon Nov 20, 2017 1:01 pm
The version I'm using:
demaseme@localhost:/> /etc/3DxWare/daemon/3dxsrv -v
3DxWareUNIX = V1.8.0, ID 10505
Post by UtaSH » Wed Nov 29, 2017 2:04 am
Hello demaseme,
officially we do not support ubutnu. Thus we haven't tested our driver on ubuntu.
Have you tried with
su -
/etc/3DxWare/daemon/3dxsrv -d usb
nlc
Post by nlc » Mon Aug 27, 2018 4:25 pm
Yes he did and ther is the same problem ! I heard of a small C code some one compile to make it work and i did a long time ago but i do not remember what one need to do with it !!
https://forums.gentoo.org/viewtopic-t-6 ... e36149df5b
If you solve the problem pleas update
nour
Post by nour » Wed Feb 13, 2019 7:45 am
So basically, the link takes me to the other forum that contanis a link to this forum ?
Anyway, juste compiling a code can not fix the problem, that must be some "make" file out there to deploy to binary file.
Presstheredbutton
Post by Presstheredbutton » Tue Jan 14, 2020 3:06 am
Same error here, did someone ever found a solution to this?
Any help will be higly appreciated
gjrtimmer
Post by gjrtimmer » Sat Apr 25, 2020 5:38 am
@ALL
Solution to get driver running in Ubuntu; the issue is the linking to the USB UserSpace.
Run the following command as your user; Yes as your normal USER; and its correct to use SUDO.
We want to remain in our current UserSpace, elevate to ROOT while maintaining our current environment.
The variable ${USER} is automatically replaced by bash with your own username, so you can copy paste this command.
sudo /etc/3DxWare/daemon/3dxsrv -userName ${USER} -firmware usb
Result:
timmer@Aeris:~$ sudo /etc/3DxWare/daemon/3dxsrv -userName ${USER} -firmware usb
Device      = SpaceNavigator
Firmware    = V4.31
Firmware = V4.31
It showed it was able to connect to the space navigator, and read its firmware through USB.
Now continue.
sudo /etc/3DxWare/daemon/3dxsrv -userName ${USER} -d usb
If I then open a second terminal and laucn xcube from the install package; I'm able to control the cube with my space navigator.
Hope this helps a lot of other people.
@3DConnection
You're linux install script is flauwed, several if statements are incorrect, does not matter that you do not support ubuntu; the install script gives errors because there are elemental BASH errors in your install script; if you want I can help you rewrite it.
Let me know by sending me an email.
