Applications by linux-users
Absum
Post by Absum » Tue Apr 24, 2007 4:21 am
Is there anyone out there who has made applications in linux for the space navigator? It would be nice to hear from anyone who atleast have tried
Post by UtaSH » Thu Apr 26, 2007 1:53 am
Hi Absum,
have you had a look to our SDK for Unix/Linux? If you want to work with it I can send you some documentation for it.
Absum
Post by Absum » Thu Apr 26, 2007 3:56 am
Thanks some documentation would really be helpfull, I seem to be stuck at the moment trying to initialize the SDK/driver.
include/xdrvlib.h:68: error: too many arguments to function 'int MagellanInit()'
include/BaseFrameListener.h:145: error: at this point in file
even tho the call is MagellanInit(xd, xw)
Post by UtaSH » Thu Apr 26, 2007 6:15 am
Please try this:
add the following lines to xdrvlib.h
#ifdef LINUX
#define ParameterCheck
#endif
or in case you did not #define LINUX only this
Absum
Post by Absum » Thu Apr 26, 2007 6:29 am
g++ -o bin/release/main src/main.o include/xdrvlib.o -L. -lOgreMain -lOIS -lX11
src/main.o: In function `BaseFrameListener::setupSpaceNav(_XDisplay*, unsigned long)':
main.cpp:(.text._ZN17BaseFrameListener13setupSpaceNavEP9_XDisplaym[BaseFrameListener::setupSpaceNav(_XDisplay*, unsigned long)]+0x15): undefined reference to `MagellanInit(_XDisplay*, unsigned long)'
Still get basically the same error as i've gotten the last couple of hours i've tried getting this to work with ogre3d. The function is there and it takes the right parameters but me thinks it looks like its the linking thats the error.
Post by UtaSH » Thu Apr 26, 2007 6:55 am
The message looks af if xdrvlib.c was not compiled and the linker can't find the xdrvlib.o ??
Are there any other warnings or errors before the linker message?
Absum
Post by Absum » Thu Apr 26, 2007 7:06 am
No thats the only one... im using scons building system and im pretty sure it builds and links in the xdrvlib.o. But i do get the same error when not linking in xdrvlib.o :O
Absum
Post by Absum » Thu Apr 26, 2007 7:40 am
scons
scons: Reading SConscript files ...
Checking for C++ header file Ogre.h... (cached) yes
Checking for C++ header file OISPrereqs.h... (cached) yes
Checking for C library OgreMain... (cached) yes
Checking for C library OIS... (cached) yes
scons: done reading SConscript files.
scons: Building targets ...
g++ -o bin/main.o -c -Wall -Iinclude -I/usr/include/OGRE -I/usr/include/OIS src/main.cpp
include/xdrvlib.h:93: warning: 'int MagellanErrorHandler(Display*, XErrorEvent*)' declared 'static' but never defined
g++ -o bin/main bin/main.o src/xdrvlib.o -L. -lOgreMain -lOIS
bin/main.o: In function `BaseFrameListener::setupSpaceNav(_XDisplay*, unsigned long)':
collect2: ld returned 1 exit status
scons: *** [bin/main] Error 1
scons: building terminated because of errors.
Here is the whole output with -Wall specified.
Post by UtaSH » Thu Apr 26, 2007 8:19 am
I can not see from the messages when the xdrvlib.c is compiled.
Can you find it in your directory src?
Absum
Post by Absum » Thu Apr 26, 2007 2:44 pm
scons
g++ -o bin/main.o -c -Iinclude -I/usr/include/OGRE -I/usr/include/OIS src/main.cpp
gcc -o include/xdrvlib.o -c include/xdrvlib.c
ar rc src/libxdrvlib.a include/xdrvlib.o
ranlib src/libxdrvlib.a
g++ -o bin/main bin/main.o -L. -lOgreMain -lOIS src/libxdrvlib.a
There, i've modified the buildscript so that xdrvlib is compiled as a static library, don't know if that is correct but i get the same error and you can see that it compiles.
I've also created a new thread about this in the linux development forum... thought it would be more appropriate
Post by UtaSH » Fri Apr 27, 2007 12:58 am
True. This thread makes more sense in the Developer's Forum for UNIX/Linux. See here.
