MacOS 11.00 (Big Sur)
cjadams
Re: MacOS 11.00 (Big Sur)
Post by cjadams » Mon May 31, 2021 9:46 am
Here is hoping this is solvable.. i would up the priority over almost everything else till this is done.. But also UE5 on PC and mac.. as well. would be nice if its easy?? ;)
Post by ngomes » Mon May 31, 2021 12:49 pm
On Mac, there's nothing higher than restoring the virtual keyboard feature.
We're never that lucky... There is interest in Unreal for Mac, so we'll have to address it as well, imo.
zoomer
Post by zoomer » Mon May 31, 2021 1:01 pm
Indeed.
At least since UE5 preview ....
marcarch
Post by marcarch » Tue Jun 01, 2021 1:41 am
Meanwhile could you concentrate on other features too?
phil8900
Post by phil8900 » Wed Jun 16, 2021 3:44 am
phil8900 wrote:
Sun Jan 03, 2021 6:29 am
To be sure that the mouse button is not working and the issue is not a problem with Archicad I used the following web page:
https://www.onlinemictest.com/de/maus-test/
The mouse wheel button doesn't do anything when the Cadmouse is connected via Bluetooth. I then tried to use the mouse with a cable but that didn't change the behaviour.
The mouse wheel button is working with a different mouse.
This issue is still bothering me. Could this be related? I don't see mouse options for the middle button in the mouse settings dialog.
https://discussions.apple.com/thread/252453004
Post by ngomes » Wed Jun 16, 2021 5:47 am
I think the issue you referring to is this:
Perhaps the wheel button is disabled in the relevant driver configuration? Go to the 3Dconnexion pane in System Preferences and check if the wheel button is enabled (and what it is assigned to) in the configuration used for the target application.
phil8900
Post by phil8900 » Wed Jun 23, 2021 12:24 am
Now I feel utterly stupid :| This solved the issue for me, the keystroke previously assigned to the middle button was assigned to the mouse wheel click in the settings, but I'm pretty sure I didn't change that.
Anyways, thanks for pointing me in that direction..
Post by ngomes » Wed Jun 23, 2021 1:14 am
Excellent. Good to know it's sorted.
We are not aware of any setting changing without user intervention. This would be a bug in a driver, one we would be very keen to fix.
