ngomes wrote: ↑Fri Oct 22, 2021 2:47 am
To use the original CadMouse on macOS 11, you need the latest firmware (version 1.06). More details
here.
If your CadMouse can be used as a regular mouse on macOS 11 (button clicks work as expected), then you already have firmware v. 1.06.
In all likelihood, you have configured your CadMouse differently from your SpaceMouse Enterprise and SpaceNavigator but this is only an educated guess.
Yes, I have the latest available Firmware installed
(Which was necessary since the first Big Sur)
And yes it clicks work as expected.
I didn't change my CADMouse configuration before having that problem at all.
I just tried to use alterative settings "after" the problems appeared.
I could check if it works with the previous Beta Driver again.
If not, it would be caused by the macOS latest 2 PB Updates.
Today there was another 12.01. (!?) update.
So I am on Build macOS 12.0.1 (21A559)
