been running archiCAD 11 on MAC OS 10.5 leopard. using the 3d space navigator PE in 3D mode i'm unable to fly around and navigate my model as i normally would with just the explore tool. it seems to rotate the model as a whole in lieu of moving the viewer/camera. the way its navigating currently is just a bit clumsy and the model seems to rotate about an invisible axis.
i've set the space navigator to archicad 11 settings and messed with all of the settings that i could find. is there a setting in archiCAD that i need to change?
i've used the navigator in google earth as a test and it seems to be working normally, so i'm at a loss here.
I reinstalled the latest driver after installing sketchup and now it works, like PS CS3 and artlantis... i keep the same problem on archicad, i've followed all the threads in the forum but i can't fix, in perspective left and right buttons work, bur it doesn't move in the model!
