64-bit support for Snow Leopard?
Mux
Post by Mux » Mon Oct 12, 2009 9:15 am
I own a SpaceNavigator which I like lots, but my Mac runs in 64-bit mode by default and every time I want to use the SpaceNavigator I have to reboot in 32-bit mode, which is very inconvenient!
Wil a 64-bit clean recompile of the driver be released anytime soon? Thank you. :)
Bryan
3DxMacWare
Post by Bryan » Mon Oct 12, 2009 12:09 pm
Dear Mux.
What driver version do you read in the 'About 3Dconnexion' under the 'Configuration' dropdown in '3Dconnexion' Control Panel under 'Others' in 'System Preferences'?
Sincerely,
Bryan
kyoseki
Post by kyoseki » Mon Oct 12, 2009 5:09 pm
Same problem here, no worky, no little blue light.
Installed the latest driver version, 1.5.7, the system preferences panel says (32-bit) though.
Bryan
Post by Bryan » Thu Oct 15, 2009 11:14 am
Dear kyoseki,
It doesn't work at all, or is it just that the blue light is turned off? Does it work in the demos?
Sincerely,
Bryan
seacrets
Post by seacrets » Fri Oct 16, 2009 12:36 pm
Same problem here. Snow Leopard 64 bits not working. Snow Leopard 32 bit, working. Possibly need to recompile the driver.
Dear Bryan: It does not work at all. The blue light is off, the demos doesn't work (in 64 bit mode)
Latest version (to my knowledge) 1.5.7
Re: 64-bit support for Snow Leopard?
Post by UtaSH » Mon Oct 19, 2009 2:36 am
Hi all,
unfortunately we could not confirm the current Mac driver to work for both: 32bit and 64 bit. Sorry for the delay. We are now working on a solution for 64bit, too. Please be patient and check from time to time our download site for a new release.
seacrets
Post by seacrets » Wed Oct 21, 2009 11:21 am
New version 1.5.8 Still doesn't solve the problem.
I'll keep an eye for upcoming updates
Mux
Post by Mux » Thu Oct 22, 2009 5:46 am
My version at the time of posting was 1.5.7, but 1.5.8 is the same story. The device doesn't work at all as others have explained.
Good to hear work has started on a solution. Thanks for the information. :)
e.bardiere
Post by e.bardiere » Thu Oct 22, 2009 10:59 am
Seem to be ok with google earth
Mux
Post by Mux » Fri Oct 23, 2009 3:19 pm
Are you sure you run in 64-bit mode? You can check this by opening the System Profiler, then choosing "Software" on the left and check if "64-bit Kernel and Extensions" says "Yes".
seacrets
Post by seacrets » Tue Nov 24, 2009 12:43 pm
uludwig wrote:Hi all,
Hello, do you have any expected release time for the new driver? (some weeks, some months..)
Thank you
seacrets
Post by seacrets » Thu Jan 14, 2010 10:07 am
Thank you
Maybe a couple of years then...
goku
Post by goku » Sat Feb 27, 2010 4:30 pm
I have the same problem.
I running Snow Leopard 10.6.2 (64 bit mode). I try to install Space navigator without success to use with Osirix 3.6.1 64-bit
dggraphics
64bit Support?
Post by dggraphics » Fri Mar 05, 2010 2:26 am
Any update as to what is happening with 64bit support? Would like to e able to boot up in 64bit mode
Mux
Post by Mux » Fri Mar 12, 2010 4:22 am
Uta, could you give us an estimation about a release date?
