SpaceNavigator and Maya 2011
SpacyRicochet
Post by SpacyRicochet » Wed May 05, 2010 11:56 pm
I just got my Macbook Pro with Snow Leopard and installed Maya 2011 with an unlimited network license.
Afterwards I've installed the drivers for my SpaceNavigator, and the demo's seem to work fine. The driver also installed the control panel in Maya 2011 itself, so I can access that and the button editor. However, when in a scene, it still fails to listen to any input I give from the device.
I've already tried using
MagellanStartup;
in the MEL console, however then it gives me the following error:
//Error: Plug-in, "3DxMaya.bundle", was not found on MAYA_PLUG_IN_PATH.
Any ideas?
Fred
Post by Fred » Thu May 06, 2010 6:25 am
Sorry, Maya 2011 addin hasnt been released.
Developers are still working on the Mac driver.
Periodically check the 3DXlabs for the Beta release when it becomes available.
http://www.3dconnexion.com/supported-so ... xlabs.html
SpacyRicochet
Post by SpacyRicochet » Thu May 06, 2010 11:50 pm
No problem.
I had to downgrade to 2009 because the uni's render farms don't support any newer version and it works great now.
Insect
Post by Insect » Tue Jun 01, 2010 11:36 am
How is it going with the maya 2011 driver for mac? It has been a while and no beta driver in 3dxlabs yet :(
BooME
Post by BooME » Thu Jun 03, 2010 2:08 pm
Yeah. I am also waiting for this driver and I hope it´s come out soon. :cry:
Fred
Post by Fred » Tue Jun 22, 2010 2:47 am
We have a beta version of 3DxWareMac on our 3DxLabs site: http://www.3dconnexion.com/supported-so ... xlabs.html. This version includes support for Maya 2011 and Photoshop CS5.
BooME
Post by BooME » Sun Jul 04, 2010 3:23 pm
I had some problems with the installation but I have installed it manually and it works great.
Thank you 3DxLabs Team!
BooME
Post by BooME » Wed Jul 21, 2010 12:07 pm
How Can I disable the Rolling function only for the Camera "Fly Mode"? I like the Object Movement very much. But that make sense only with the Rolling function.
On the other side, I like the Fly Mode without the Rolling function. So I have to click every time the "Disable Rolling" button. :-(
Post by UtaSH » Thu Jul 22, 2010 2:01 am
Hello BooME,
you can do all the mentioned settings in the 3Dconnexion panel in Maya.
:!: If you open the Button Mapping Editor you find as well in the category "3Dconnexion" many commands. This way you can map the toggle of e.g. "Disable Rolling" to one of the buttons. All other commands can be found there as well.
jazioblaq
Maya 2011 Support
Post by jazioblaq » Sat Aug 21, 2010 8:07 am
I checked the beta link. Says it only works up to Maya 2010
? Still cannot get it to work in 2011
Re: Maya 2011 Support
Post by UtaSH » Mon Aug 23, 2010 4:55 am
Hi jazioblaq,
please use the latest version of 3DxMacWare. It is version 1.6.1 and includes support for Maya 2011.
mtr0212
Post by mtr0212 » Wed Oct 27, 2010 5:21 pm
Same problem here; macbook pro 2009, osx 10.6.4, maya 2011, space navigator usb.
works good on google earth and rhino, not in maya 2011, not in autocad 2011.
I installed drivers v1.6.1, so, how can i fix this? any tips?
thanks.
flomotan
Post by flomotan » Fri Oct 29, 2010 9:16 am
AutoCAD 2011 for the Mac does not currently support a 3D mouse. We are contacting Autodesk to see if 3d mouse support can be enabled in a future version. If you have time, please also send them a note. It may help them prioritize this task properly.
With regards to Maya 2011, please check that the plug-in files are properly installed
- Confirm the plug-in 3DxMaya.bundle is in Users/Autodesk/maya/2011/plug-ins
- Confirm these files are in Users/Autodesk/maya/scripts
C3DxButtonEditor.mel
C3DxControlPanel.mel
C3DxMapping.mel
MagellanStartup.mel
usersetup.mel
- Can you look at the MEL script console after startup and paste the output here?
- Go to Maya Window->Settings/Preferences->Plug-In Manager and check that 3DxMaya.bundle is loaded
Finally, try typing the MEL command:
MagellanStartup;
mvanrijzewijk
Post by mvanrijzewijk » Mon Nov 01, 2010 1:42 am
Just a quick note, on my Mac the directory is actually:
Users/Shared/Autodesk/maya/2011/plug-ins which has the 3DxMaya.bundle. file
and
Users/Shared/Autodesk/maya/scripts where the .mel files are
lutzministrator
Post by lutzministrator » Wed Feb 02, 2011 8:55 am
PostPosted: Mon Nov 01, 2010 12:42 am Post subject:
and
and that's the problem! 3dxwaremacSE actually installs the files into the wrong directory. What worked for me is while installing the drivers, manually moving the relevant (icons, scripts, .bundle) files from the temporary folder which is created by the installer in the shared folder (it only exists for the duration of the setup!).
After restarting, you copy the icon files into the shared/autodesk/maya/2011/icons, the .mel files into shared/autodesk/maya/2011/scripts and most important, the correct 3DxMaya.bundle (has to be 2011! copying the 2010 bundle won't work due to the different architecture) into shared/autodesk/maya/2011/plug-ins
Maybe 3Dconnexion could release another installer which fixes that??
