CAD mouse wireless won’t click on MacBook Pro?
Jorge_rui
Re: CAD mouse wireless won’t click on MacBook Pro?
Post by Jorge_rui » Sat Apr 14, 2018 2:10 pm
henke wrote:
Fri Apr 13, 2018 4:11 am
I made it!
– I uninstalled the original driver.
– Then I installed the old one the Jorge linked to.
– Then I allowed the kernel extension as UtaSH mentioned.
– Restart.
– Now I installed the most recent driver.
– Restart.
– Allowed the kernel extension again.
Now it works!
Nice. That is the proof of what I’m saying for weeks now, the newer driver is broken
henke
Post by henke » Mon Apr 16, 2018 3:35 pm
Well, I think its rather about the kernel extension actually. But anyway, it worked for me. Hope it works for you too.
Post by UtaSH » Wed Apr 18, 2018 6:59 am
Jorge_rui wrote:
Sat Apr 14, 2018 2:09 pm
That is not an option on the newer driver. It’s broken, I’m saying that for weeks now
Hi Jorge_rui,
Are you working directly at your mac or are you connected remotely to it? (See here.)
It could be as well that you have another 3rd party driver installed that is asking for approval. Check if this is the case and if yes uninstall that software. You should then have the possibility to "Allow" the 3Dconnexion kernel extension.
Jorge_rui
Post by Jorge_rui » Thu Apr 26, 2018 5:32 am
I'm not using nay kind of virtualization.
If you are using that on your test machine, don't. A think that no one that make any serious/profissional CAD work uses things like Parallels or virtualBox, etc...
Post by UtaSH » Fri Apr 27, 2018 1:33 am
... A think that no one that make any serious/profissional CAD work uses things like Parallels or virtualBox, etc...
Agreed. :)
whyrichard
Post by whyrichard » Thu Jun 21, 2018 1:01 pm
I finally got this working in high sierra, by installing the old driver and then installing the new driver, allowing for the new security setting.
It finally worked. But when I restarted just now it is back to no longer clicking.
i can't believe a simple mouse is having so many technical issues. is there a fix for this yet?
r.
Post by UtaSH » Mon Jun 25, 2018 7:09 am
Maybe this post has helpful information for you.
ColdShower
Post by ColdShower » Fri Jan 29, 2021 7:31 pm
This is what you need to do. I Had the same problem.
Go on a windows machine or windows virtual machine and plug you Cad Mouse via cable.
Then Download Firmware update for mouse here https://www.3dconnexion.com/technical_s ... r17928.exe
It will recognize the mouse automatically or if you have more 3D connection devices choose your CadMouse from the Dropdown menu.
Hit update and then when your firmware is updated go and plug your mouse to your mac. Install the Big Sur beta https://3dconnexion.com/uk/support/faq/ ... 1-big-sur/
and Voila. Now you can connect your mouse via bluetooth if you wish.
It worked for me after all other suggestions failing.
Hope this helps
Post by ngomes » Mon Feb 01, 2021 1:26 am
Link to the FAQ page with the firmware update tool CadMouse Wireless is here.
The FAQ page is maintained but deep links to download locations will eventually be removed after newer software is made available.
