3DConnexion Drivers for MAC OS Catalina?
O_Pablo
Re: 3DConnexion Drivers for MAC OS Catalina?
Post by O_Pablo » Sat Oct 26, 2019 12:39 am
Any sounds about the new driver for macOS Catalina?
My suggestions for the future, maybe you should be interested in preparing a new driver with starting the beta version?
You offer a great device, but the lack of support for the new version of the operating system for almost a month since is very frustrating.
UtaSH wrote:
Tue Jul 30, 2019 2:17 am
Hi marcel_911,
macOS Catalina isn't yet released. We don't support beta software.
Regards,
Paul
marcarch
Post by marcarch » Sat Oct 26, 2019 2:35 am
:lol: :lol: :lol:
I’ve lost all my hopes with 3Dconnexion...
fnxf_scewo
Post by fnxf_scewo » Sat Oct 26, 2019 11:46 am
UtaSH wrote:
Thu Oct 10, 2019 12:40 am
Hi all,
we are currently testing our next release of 3DxWareMac. Depending on the results of the testing phase we will publish this version, which will include official support for maxOS 10.15 (Catalina).
When do you expect to be done with the testing phase?
Indyjet1
Post by Indyjet1 » Sun Oct 27, 2019 4:05 pm
Please let us know when Catalina will be supported. This is a problem.
Indyjet1
Post by Indyjet1 » Mon Oct 28, 2019 11:28 am
Any updates on this. Very frustrating !
sakumar
Post by sakumar » Mon Oct 28, 2019 4:12 pm
I read user mariocha's comment on this thread from October 22 that his 3dconnexion device is working on Catalina.
I just unplugged/plugged in my spacenavigator and it is working on MacOS Catalina 10.15! I didn't have to do any 3dconnexion driver update.
Oh, and I only use it for Autodesk Fusion 360 -- for which it is now working -- can't say much about other apps.
O_Pablo
Post by O_Pablo » Tue Oct 29, 2019 2:04 am
mariocha wrote:
Tue Oct 22, 2019 1:41 pm
I just installed Catalina and my Space Navigator works just fine. :D
I guess Apple corrected something.
Ha,
the problem is that, time to time macOS Catalina on my MBP (Mid 2015) is recognized SpaceMouse for notebooks, and is working well, but after restart computer system again not recognize the device.
Regards
Paul
uprightgumby
Post by uprightgumby » Tue Oct 29, 2019 8:26 am
Had this same issue. Re-installed current 3DxWare 10 for macOS and restarted. One thing to note, and this has been a recurring problem with Apple for some time, you must unplug your USB Space Mouse and plug it in again for it to work. Maddening, but it works.
MACOS 10.15 Catalina
Good luck!
O_Pablo
Post by O_Pablo » Tue Oct 29, 2019 2:09 pm
Apple updated macOS Catalina to 10.15.1 version. Old driver now work properly but run slowly :wink:
Regards
Paul
roger
Post by roger » Tue Oct 29, 2019 9:55 pm
with or without driver? I tried with driver a few weeks ago and it didn't work without driver it works basically.
Alex100
Post by Alex100 » Fri Nov 01, 2019 9:56 pm
Still no luck here. MacBook Pro with Catalina 10.15.1 with a usb SpaceNavigator. 3DxWare 10.6.3.
The Spacenavigator will move the pointer and the ring light is on, but it's not recognised by 3Dconnexion control panel which just says no device found.
Any ideas?
blaiseb@mac.com
Post by blaiseb@mac.com » Sat Nov 02, 2019 10:07 pm
I have installed Mac OS Catalina today with updates to 10.15.1 and I confirm that the wired version of the space navigator is working fine. In Fusion 360 anyway. Also, before Catalina, I needed to disconnect/reconnect de USB wire for the 3D mouse to be recognized after computer restart. Now, no need so I'm quite pleased!
- Blaise
xyzt
Post by xyzt » Wed Nov 06, 2019 4:26 am
Regards
Paul
Hi, I had the same problem.
I Installed Catalina 10.15.1 after I saw that 3DxWareMac_v10-6-4_r3069 was released, claiming to be Catalina Compatible.
But After I upgraded and installed v10-6-4_r3069, my SpaceMouse Enterprise didn't show up.
(My CadMouse did show up in the System Preference -> 3dConnexion)
Inspired by the above post I started trying older drivers and here are my findings:
After downgrading the driver to 3DxWareMac_v10-6-3_r2986 (didn't solve the problem)
I again downgraded to 3DxWareMac_v10-6-3_r2986 and it Worked. So I can Confirm that this older driver is working in Catalina.
The SpaceMouse Enterprise shows up in System Preference -> 3dConnexion and it works in Sketchup And Fusion again.
I haven't fully tested if it works as in Mojave, but at first use it feels normal.
Hope this wil help someone with the same problem and for 3dconnexion its maybe a clue to why its not working in the lastert drivers.
Regards,
xyzt
Post by UtaSH » Thu Nov 07, 2019 5:09 am
Hi all,
we have published 3DxWareMac 10.6.4 on Nov 3rd. Please download this version for macOS 10.15. In case you still have problems I recommend the following procedure:
  • Uninstall any 3Dconnexion driver software.
  • Reboot the machine.
  • Install 3DxWare 10.6.4.
  • Reboot.
Make sure you follow the instructions from this FAQ as well.
graemef
Post by graemef » Thu Nov 07, 2019 5:17 pm
I am running a 2018 MacMini with Mojave and have both a SpaceMouse and CADMouse. Following the steps outlined in the previous post I upgraded to 10.6.4 but the left hand button of he CADMouse is not functioning. SpaceMouse works fine.
I have tried a couple of times uninstalling/reinstalling but the problem persists. The only time I can get it to work is when I downgrade to 10.6.1
Any suggestions for fixing the left hand button on the CADMouse using 10.6.4 or should I permanently run 10.6.1 - at least until I upgrade to Catalina.
Thanks...
Graeme
