I have iOS 10.10.5 in MBP 15 " RETINA and the spacemouse and cad mouse can't used the radial menus in any application, no show nothing when press the button.
What did i should do?
Thanks Laura
NOT RUN RADIAL MENUS AT ALL
Re: NOT RUN RADIAL MENUS AT ALL
Hi LAUMVY,
It may be - for some strange reasons - that the com.3dconnexion.mappings.plist file is messed up.
So please try remove it (you may want to have it backed up before!) from ~/Library/Preferences/.
(Please note: Before removal, close the System Preferences and thus the 3Dconnexion prefs.)
If you now reopen the 3dconnexion prefs, a new/clean com.3dconnexion.mappings.plist is created.
Does this solve your problem?
It solved the problem for me.
