10.6.6 and before, crashing in Maya 2020, 2021, 2019 etc. on OSX
Climberfx
Post by Climberfx » Sat Aug 08, 2020 6:34 am
Besides the fact that i already pass thought you guys my crash logs etc on the version 10.6.4, for a weird behaviour on OSX (Mine is High Sierra), when i use Spacemouse the moment i release it, the viewport do some glitches for a fraction of a second, and stop. Some times it stop in the position i start moving, not the desired one.
But in 10.6.5 it start to crashes Maya from time to time. So i had to use it las, so i could work more with Maya.
In this new one 10.6.6, it still crashes, but not Maya, so now it's a little bit better, because Maya won't crashes, only Spacemouse, from time to time, it stops from working inside Maya, and then i need to close and reopen Maya, it will crashes first time after it, then open Maya again and spacemouse turn to work for a bit more.
And then the cycle repeats.
Not of that happens when i use it under Windows 10.
Thank you.
p.s.: Let me know if you need more details, log files etc.
