MacOS 11.00 (Big Sur)
bmxjeff
Post by bmxjeff » Mon Aug 10, 2020 11:58 am
I have not had much luck with the 3D mouse in MacOS 11.0. The drivers are installed and listed in "Extensions" under the Software heading. The CAD mouse works great! But none of the Space Mice work.
To install them I had to disable "SIP" on the OS in recovery mode.
If anyone get's a temporary workaround or a beta, that would be great. I feel like I lost a hand : )
Re: MacOS 11.00 (Big Sur)
Post by UtaSH » Tue Aug 11, 2020 2:55 am
Hi bmxjeff,
we are working on a solution for Big Sur. We aim to be able to provide a solution once this OS version is officially released (no beta).
RicoHo
Post by RicoHo » Wed Aug 19, 2020 11:09 pm
Many companies already have published drivers for Big Sure. I'm in contact with many developers and often they need only some days to adapt their drivers and publish them. Why is 3Dconnexion so slow and not interested in supporting their users in this case?
RicoHo
Post by RicoHo » Wed Aug 19, 2020 11:11 pm
I think it would be very helpful if you could publish a beta of the new driver here.
monkeygrip
Post by monkeygrip » Mon Sep 21, 2020 1:44 pm
i just tried and disabling SIP and it didn't work. how did you do it?
cjadams
Post by cjadams » Tue Sep 22, 2020 2:39 pm
yeah still not drivers.. still no word.. they clearly don't want to even try as a company.. ever heard of anyone beta testing for them? I havent
GarthSnyder
Post by GarthSnyder » Tue Sep 22, 2020 2:46 pm
I've seen in several places that some new procedure is needed on Big Sur, but the past procedure seemed to work fine for me: reboot in recovery mode, open the Terminal window, and run "csrutil disable". Once the system is rebooted normally, "csrutil status" still shows SIP as being disabled.
Although disabling SIP seemed to work, this had no effect on the SpaceNavigator drivers, which still don't even see the device. Perhaps the OP meant that disabling SIP was necessary to get the mouse devices to work?
zoomer
Post by zoomer » Tue Sep 22, 2020 4:22 pm
They said there will be no Driver for a Beta,
just for when something will have been released.
So for Big Sur there might be still a few weeks of time ...
(Not to talk about Macs with Apple Silicon ...)
bmxjeff
Post by bmxjeff » Thu Oct 08, 2020 9:54 am
It does make it tough to develop tools that use 3D Connexion devices, when we can not use 3D Connexion devices.
Maybe, it's time for 3D Connexion to get some health competition. Right now, they do not have any real competitors making 3D Controllers.
bomtarnes
Post by bomtarnes » Thu Oct 15, 2020 2:55 pm
As of Big Sur Beta 10- my spacemouse enterprise is working again- without any input from 3dconnexion. I do have SIP disabled still i believe.
GarthSnyder
Post by GarthSnyder » Sat Oct 17, 2020 12:41 pm
OMG, thanks so much for posting this -- it really made my day.
Actually, it still wasn't working for me in beta 10, but just knowing that it might be possible motivated me to do some more investigating. Here's what worked for me:
  • SIP is disabled. I had done this previously and don't know if it's necessary or not. You can tell if it's disabled by running csrutil status.
  • I reinstalled the 3DConnexion driver after deleting it by running /Applications/3Dconnexion/Uninstall 3Dconnexion Driver.app. The installation seemed to go fine, but the SpaceMouse still didn't work.
  • I noticed that the 3DConnexion kernel extension wasn't loaded. You can check for this with kmutil showloaded | grep 3dconnexion. You should see a line of output for com.3dconnexion.driver if the driver is loaded.
  • I loaded the driver by hand by running sudo kmutil load -p /Library/Extensions/3Dconnexion.kext
  • After that, I had to disconnect the USB cable to the SpaceMouse and then reconnect it in order for the driver to notice that the device was there. My SpaceMouse is wireless, but I normally use it with the cable attached; not sure what the deal would be with a wireless connection.
  • This only works for the current boot. After rebooting, I still have to manually load the driver and reconnect the SpaceMouse to get it working again. There is probably some relatively straightforward fix that associates the kernel extension to the USB device; I just don't know how to do it.
GarthSnyder
Post by GarthSnyder » Sat Oct 24, 2020 1:04 pm
Just a followup: there are good instructions for loading the driver kext at startup at https://superuser.com/questions/47233/h ... 7373#47373.
Don't use the exact command shown there; the kext system is a little different now. Here's a version that should work unmodified:
<!--See https://superuser.com/questions/47233/how-can-i-force-a-mac-os-x-kext-to-load-prior-to-login/47373#47373 -->
<!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
<plist version="1.0">
<dict>
        <key>KeepAlive</key>
        <false/>
        <key>Label</key>
        <string>com.garthsnyder.3dconnexion</string>
        <key>ProgramArguments</key>
        <array>
                <string>/usr/bin/kmutil</string>
		<string>load</string>
		<string>-p</string>
                <string>/Library/Extensions/3Dconnexion.kext</string>
        </array>
        <key>RunAtLoad</key>
        <true/>
        <key>StandardErrorPath</key>
        <string>/dev/null</string>
        <key>StandardOutPath</key>
        <key>UserName</key>
        <string>root</string>
</dict>
</plist>
Jpwolfe
Post by Jpwolfe » Tue Oct 27, 2020 3:38 pm
When I run this in Terminal, I get the message
Extension with identifiers com.3dconnexion.driver not approved to load. Please approve using System Preferences.
Any known solution for this?
Post by UtaSH » Thu Oct 29, 2020 1:27 am
Hi all,
Big Sur doesn't allow kernel extensions anymore. Our new (not yet released) driver will handle this completely different. In case you already are using a beta of Big Sur please please contact our Technical Support Team.
falconbrad
Post by falconbrad » Tue Nov 10, 2020 12:48 pm
Can we expect the new driver to drop in time for Big Sur's release in two days? Or should we still be contacting you guys to get access to your driver beta?
