Maya 2012 - Where are instructions on how to make it work?
I've got the "3D Control" menu showing. But the SpaceNavigator doesn't do anything in Maya. What is to be done?
Re: Maya 2012 - Where are instructions on how to make it wor
Do you have movements in other applications, for example the demo cube?
Hello Jessy -
The 3Dconnexion plug-in in Maya depends on the command MagellanStartup being executed by the usersetup.mel
script.
Can you go to the MEL console in Maya and type “MagellanStartup” ? [without the quotes]
Either the SpaceNavigator navigation will be enabled or there will be an error indicating what the problem is.
If the SpaceNavigator starts at the command prompt but is not auto-starting, that would indicate that another
instance of usersetup.mel is being used. To have the SpaceNavigator auto-start you would need to add the line
magellanstartup;
to the end of the active usersetup.mel .
If you have other add-ins such as Maya's Bonus Tools or GoZ , they add their own usersetup.mel files.
Use 'Finder' to locate any other versions of usersetup.mel .
Open the 'usersetup.mel' in -->Maya-->scripts-->startup and add the line
magellanstartup;
at the end.
Maya only checks for the scripts on startup, so you can restart Maya or type "rehash;"
If the “MagellanStartup” command returns an error: "3DxMaya.bundle", was not found on MAYA_PLUG_IN_PATH ,
check that you are using the current 3DxMacware software and if not, download it from from our web
site under Service –Download Driver. [http://www.3dconnexion.com/support/downloads.php].If you are already using
the current version, close Maya and run the 3Dconnexion .dmg again to install the plugin.
Open Maya and go to Window->Settings|Preferences->Plug-In Manager to check that 3DxMaya.bundle is loaded
Thank You,
Fred
script.
magellanstartup;
magellanstartup;
at the end.
Thank You,
Fred
L.S,
I am working on a Window 7 64-bit machine x Maya 2013
This is my solution:
One have to edit this script:
GoZBrushToMaya.mel
This is it's address on my machine:
C:\Users\Public\Pixologic\GoZApps\Maya\GoZBrushToMaya.mel
Open it in Notepad.
At the end of thís script I added:
magellanstartup;
The end of this script now looks like this:
printDebug(" Reading object " + $objectPath + " ...");
importGoZObject($objectPath);
// Clears the GoZ objects list.
$fileId = `fopen $objectListFile "w"`;
fclose $fileId;
magellanstartup;
All the best,
Feng
GoZBrushToMaya.mel
Open it in Notepad.
magellanstartup;
fclose $fileId;
magellanstartup;
All the best,
Feng
