'3D Spacemouse-Wireless' keeps crashing. Which driver should I use? (on Windows 10 x64)
ship69
Post by ship69 » Wed Oct 13, 2021 12:34 pm
Hello
1. I recently installed version 10.8.2 (64 bit version). I am running Windows10 (x64)
2. I can't get my "3D SpaceMouse - Wireless" to work using OnShape (web). Until recently it WAS working!
3. I keep getting error message saying "3DxWare stopped unexpectedly"
And sure enough I can't get the trainer to work either.
Should I be installing the 64 bit to match my Windows operating system, or the 32 bit version?
Should I uninstall and re-install a previous version of the 3DxWare?
J
ship69
Re: '3D Spacemouse-Wireless' keeps crashing. Which driver should I use? (on Windows 10 x64)
Post by ship69 » Wed Oct 13, 2021 12:44 pm
PS I am now getting another error:
"Error: Could not locate an installed 3Dconnection device.
Please install you motion controller driver software
before proceeding."
How do I install my "motion controller driver software" ?
Should I completely re-install the file: 3DxWare64_v10-8-2_r3385.exe (64 bit version)
If so how should I best do the uninstall?
e.g. Should I use something like Revo Uninstaller to make sure that no junk is left behind?
Or should I install the 32 bit version?
Or should I install an older version?
J
ship69
Post by ship69 » Wed Oct 13, 2021 1:32 pm
Also do I need to update the firmware of my 3D Spacemouse (wireless) and if so how should I do that?
ship69
Post by ship69 » Wed Oct 13, 2021 2:23 pm
UPDATE:
Out of increasing desperation, I have now installed version 10.6.4 of the "3DxWare10" software.
I found it here:
https://3dconnexion.com/uk/archived-dri ... s-10-64bit
At least it hasn't instantly crashed... like the recommended v10.8.2.3385 was doing!
OP
bluevoice
Post by bluevoice » Wed Oct 13, 2021 2:36 pm
I have the exact same issue with the latest 10.8.2 version and I had to revert to the 10.6.4 version. Is there a solution for this issue?
Post by jwick » Wed Oct 13, 2021 11:44 pm
Sorry. My bug. This is a bug in the handling of the old original device-specific wireless receiver.
A Universal Receiver should work and the device should work with the USB cable. The device would also work with the wireless receiver built into the Keyboard Pro.
A fix will be released shortly. Date TBD.
If you want to use the device-specific wireless receiver, the best release to use is 10.7.4 (not 10.6.anything). If you go to 10.6.x you will have problems with your old saved settings.
Post by ngomes » Thu Oct 14, 2021 4:19 am
The previous software version, 10.7.4, can be downloaded from the "archive" here.
luping
Post by luping » Thu Oct 14, 2021 8:41 am
I can attest to this bug, immediately after I switched from a 3Dconnexion universal wireless receiver to SpaceMouse Pro Wireless' receiver with a 'Pro' name silk screen, the 3DxService.exe crashed, it led to the unresponsiveness of SpaceMouse Pro Wireless operation.
AnthT
Post by AnthT » Fri Oct 15, 2021 12:14 am
hmm, I tried plugging in via USB and my space mouse charges, but isn't recognised as a USB device
Post by jwick » Fri Oct 15, 2021 1:35 am
AnthT,
Windows says this when you attach it?
That's much more interesting.
I assume you have done the usual: reboot, disconnect, try a different USB port...
