spacenavigator problem
miso
Post by miso »
I have problem with my spacenavigator, it worked well but 2 weeks ago (without any update) it start rotating without any touch with it.. now its totaly useless..
I tryed to update drivers but without influence on problem..
I am running win 7 SP1 64bit
thanks in advance for any reply
pball
Re: spacenavigator problem
Post by pball »
Go to the notification area and right click on the space navigator icon and click calibrate. Do not touch the space while it calibrates. If that doesn't work either post back or try the support page to try and get it replaced if it's under warranty.
miso
Post by miso »
pball thank u very much! looks it helped.. :-) thanks again
Post by Barbara »
Hello miso -
Pleased to know the calibration corrected the problem. This can happen if the Space Navigator gets 'off-center' - that will cause unwanted movement on screen as it keeps trying to move back toward center. Calibration clears that so it stops the movement when the cap is not touched.
ken0y
Post by ken0y »
Suffering from the same issue, using a a brand new device, have tried everything under the sun but to no avail, I still get drifting. I can only assume there is a software conflict somewhere.
Cheers
