Fly and turntable have axis reversed.
feejo
Post by feejo »
I have my fly mode is perfectly the way I want it to be set, when I pull up the image goes up and so on. When I switch to turntable, it is all reversed :( is there a way to adjust the turntable too?
Bryan
Camera Moves will seem the reverse of making Object Moves.
Post by Bryan »
Hi feejo,
What program are you using?
What version of that program?
What operating system?
What release version of 3DxSoftware do you have installed?
I'm not sure what turntable mode is, but everything may be reversed on purpose for that mode.
I know in many 3D applications, the behavior of turning an object right gives the appearance of moving a camera left. So the behaviors are different if the mode you are using is representing moving an object as opposed to moving a camera view.
Sincerely,
Bryan
