SolidWorks Rotation Center
takedownca
Post by takedownca » Thu May 21, 2009 11:21 am
When using the mouse to rotate the view in SolidWorks 2009 the center of rotation is automatically the center of the screen when the rotation begins. This is very intuitive and allows one to work on a small section of an assembly without the components floating off into space due to a rotation about the assembly origin.
Is there any way to replicate this behavior with my SpacePilot? The closest I've come is using the "Set Center Point" (SCP) 3Dx command. This works, but it's inefficient and tedious, as evidenced by the workflow steps below.
1) Zoom to a small portion of an assembly
2) Make sure SCP is not active
3) Select face/point that you want to rotate about
4) Activate SCP
5) Manipulate away
6) Deactivate SCP
7) Repeat 1-6 as required
It would be great if there were something similar to SCP, but triggered off of the screen center and puck motion. The most hands-off approach would be to reset the rotation center to the screen center whenever the sensor transitioned from "moving" to "not moving". That way I could make a chain of moves, as required, to get where I need to go and not have to keep hitting a button.
The other option might be a button/command that reset the rotation center to the screen center. So instead of resetting it whenever you stopped moving, it would only reset when the command was activated. Unlike SCP, this wouldn't be a toggle that made you to turn it off or on, but it would require a separate Reset Center command to return to defaults.
What do you think?
JesperW
Post by JesperW » Sun May 24, 2009 6:24 am
Sounds like you've missed the Auto Rotation Center option.
(in the "3DControl > Properties..." menu)
takedownca
Post by takedownca » Sun May 24, 2009 9:40 am
I already use Auto Rotation Center, and it doesn't have the effect that its name implies. It seems to just change the rotation center to the model's geometric center. Working with small portions of a model is not any easier with the option enabled.
dbelflower
Post by dbelflower » Tue May 26, 2009 4:41 am
takedownca, I feel your pain. This has been discussed many times before on this forum, but there is no fix in the works for this problem that I know of. It works great in CATIA - a middle click with the mouse and your center of rotation is set. It is almost not worth using in SolidWorks.
takedownca
Post by takedownca » Tue May 26, 2009 7:28 am
I'm not designing aero or auto structures anytime soon, so using CATIA is out for now. I don't know why it's so hard getting software enhanced around here. If I had the source code for the SW addin I'd add the features myself. Unfortunately, I don't have the time to code a full blown addin myself. Hmm... maybe I can make due with a persistent macro. I'll have to check out the 3Dx API to see if they have the functions to do this. Despite a noticeable absence of 3Dx comment on this thread, I haven't given up yet.
Katalyzt
Post by Katalyzt » Sat May 30, 2009 2:38 pm
i wish this is implemented soon
jchorton4
Post by jchorton4 » Mon Jun 08, 2009 3:42 pm
I have the exact same gripe about using my SpacePilot with SolidWorks. The lack of a dynamically changing spin center completely offsets any sort of navigational benefit that the 3D mouse might provide. The omission of this feature for SolidWorks is totally unacceptable and I will probably return my SpacePilot because of this.
rstadie
Post by rstadie » Wed Jun 10, 2009 12:32 am
Thanks for all the suggestions, we now track this issue with ID 4683 and will take it from here.
Robert Stadie
pappy
Still nothing
Post by pappy » Fri Jun 19, 2009 12:19 pm
Still dosnt work in 3.7.16 version.
laurits11
Post by laurits11 » Sat Sep 05, 2009 7:53 pm
Still dosnt work in 3.7.18 version. :(
YBW
Post by YBW » Mon Sep 14, 2009 12:17 pm
Robert,
Could you give us a schedule for when this will be fixed, or at least tell us where to go to view the status of ID 4683?
Post by UtaSH » Fri Sep 18, 2009 7:47 am
Hi YBW,
our bug tracking system is not public. The status of this issue is still in progress. Unfortunately we can not give a schedule for this.
gsepp78
Post by gsepp78 » Tue Sep 29, 2009 9:14 am
This is exactly what im looking for. Any updates on this?
pappy
Post by pappy » Wed Oct 21, 2009 11:42 am
The newest version 3.8.1 dosnt support this option still.
takedownca
Post by takedownca » Wed Oct 21, 2009 12:03 pm
Unfortunately, it almost doesn't matter to me anymore whether they fix this or not because I will only use version 3.7.12. Anything newer has the screwed up configuration menu that won't let you assign macros to SpacePilot buttons.
