yes you can and it has two parts RBC9s original and my addon .
with these two space explorer works well in either xp or vista
32 bit only at this time .
if you want my addon email me im up there somewhere and ill send it to you .
OK, I solved it (after reading 15 pages), please write it to the first post, that you should disable the "HID Compilant device" before driver update procedure, or else it will give you BSOD! After installation that device disappears magically!
And any easy way to turn off LED? For me its:
1. Exit RBC9
2. Start 3DConnexion driver where I've set no LED.
3. Exit 3DConnexion
4. Start RBC9, and do _not_ edit the layout.
Not me myself, but a friend is a guru and probably can fix the .inf problems. If it's ok for you, send me over the current driver and I will let him check.
I have a question concerning the SN :
I want to use the Space Navigator only as a game controller.
I only need three axes X, Y and Z rotation.
Is there a possibility to change the firmware according to my needs?
In the driver's manual (DONE Space navigator driver) I read that it is possible to change something on the second line.
I only have basic knowledge concerning the software, could you please help me with this problem.
Awesome job on this 'lil driver but... i can't use it. Im running on XP x64 and after instalation it doesn't see this driver(i mean when i'm. trying to update it). Is there any possibility that you will post *.inf file only ?
