8 sections radial menu barely usable :(
Keerah
Post by Keerah »
Take a look at the screen shot attached
I needed 8 macros... no text labels, same icons.... :?:
cadymfg
Re: 8 sections radial menu barely usable :(
Post by cadymfg »
I have the exact same issues. There really needs to be an easy method to assign custom icons to macros.
I read some post about editing the cfg and xml files, but it is likely over my head.
Grimmy
Post by Grimmy »
Completely agree! I have the same issue, I just posted my own message before I just saw this one. Hopefully they can make a quick fix. It doesn't sound to hard for them to add the text again. They probably only removed it because it didn't 'fit' into the little segments but TBH I don't care how bad it might look, I just need it to be functional. Really small text is also fine for me.
Hi all,
thank you for your feedback. We are tracking this feature request with our internal number #7439.
mhoopes
Post by mhoopes »
I see there's another thread related to #7439. I posted a concept for icons + text there:
viewtopic.php?f=25&t=33773&sid=ea2a1156 ... 7f6#p67918
Michael Hoopes
antonynealrobinson
Post by antonynealrobinson »
Has the 8 section radial problem been resolved in the latest driver software?
mhoopes
Post by mhoopes »
Not as of 3DxWare 10.5.4. I'd be interested in those threads describing editing of the xml files; how does one access icon resources and application commands? ProE.xml has a large number of AppCommand ButtonAction entries, and there are quite a few associated icons in 3DxWare.
Here's that radial menu concept I mentioned earlier:
Michael Hoopes
Fyuzinfected
Post by Fyuzinfected »
Hi!
Is there any news about this?
Greetings from Portugal.
Fábio Martins
Keerah
Post by Keerah »
Half year is gone, the problem isn't any near the solution.
All the 3DConnexion experience is getting so frustrating :(
Fyuzinfected
I had expectations to buy SpaceMouse Pro.
But after this problem with the Cadmouse I will suspend the purchase.
I hope you find a solution quickly.
I'm a bit disappointed with this brand.
Fábio Martins
antonynealrobinson
I can confirm that 8 section radial menus still do not work with latest drivers 10.5.5 on Creo 4.
I have tested both mapkeys from Creo and also creating macros in the 3d spacemouse settings and there is still no text.
AxeGunKnife
Post by AxeGunKnife »
Keerah wrote: Fri Jan 26, 2018 6:15 pm Half year is gone, the problem isn't any near the solution.
And I'm also very disappointed !!! Previously, I recommended to all my colleagues to purchase a spacemouse ... I'm already not recommending it. More than a year they can not solve this trifling problem.
Keerah
Post by Keerah »
AxeGunKnife wrote: Thu May 03, 2018 10:35 pm
Same here, cannot recommend it any more
antonynealrobinson
Such a shame as it's a tool that I can't be without. Such a simple problem should not be that difficult to fix. Come on 3dconnexion. Pull your fingers out and get it sorted. Users are paying a lot of money to use your products. Don't let them down with sloppy aftercare.
dnashj33
Post by dnashj33 »
antonynealrobinson wrote: Fri Jul 06, 2018 3:45 pm Such a shame as it's a tool that I can't be without. Such a simple problem should not be that difficult to fix. Come on 3dconnexion. Pull your fingers out and get it sorted. Users are paying a lot of money to use your products. Don't let them down with sloppy aftercare.
This comment is over the top. The 8 sections work on my end, they just don't show the text. I'm not concerned about allowing custom icons, just display the text, so we can see what we tools are where.
Hovering over a section does show the name of the tool, but we should see text by default. Truncate the text if it's over a certain number of letters. But being abrasive and abusive (in this comment) is unwarranted, here.
