SpaceMouse Enterprise turn off screen
andyn33
Post by andyn33 » Mon Mar 26, 2018 1:16 pm
Is there a way to turn off the screen, or disable the SpaceMouse Enterprise when not in use?
Would be good if this action could be linked to a macro key, or directly a button on the 3d mouse.
Thanks!
christophe
Re: SpaceMouse Enterprise turn off screen
Post by christophe » Fri Mar 30, 2018 1:18 am
Hi Andyn33,
If you are not using any other 3Dconnexion devices, I think the simplest solution for what you are asking is simply to turn off the driver whenever you don't use the mouse (Windows=>3Dconnexion=>Stop driver), this will shut down the LCD.
Post by jwick » Mon Apr 02, 2018 5:56 am
I've heard before a request for having the LCD give an indication that the current app is not supported (like dimming it per application). It's an interesting request.
Post by jwick » Wed Apr 11, 2018 1:40 am
I added SME LCD On, Off, *2, /2 and Toggle functions for the next release.
They can be made global so they are always on the same button in every application.
37823
Post by 37823 » Sat Nov 17, 2018 2:20 pm
Hi jwick,
thank you for your support.
Unfortunately I struggle to find the options in version 10.6.0 (mac) - are they already added?
Please inform me I this feature was plugged from the list, in which case I would consider swapping the SME for a SMP.
Post by jwick » Wed Nov 21, 2018 9:08 am
This is a Windows-only feature.
Appalachianspirit
Post by Appalachianspirit » Mon Mar 25, 2019 3:42 am
Do we have any idea when this feature will be available and how to find out how to actually do it when it is?
