Not start driver automatically
arpruss
Post by arpruss »
1. How can one prevent the 3dxware driver from starting automatically on Windows startup?
2. Failing that, can I get the driver to stop at least? I manually stop the driver, but eventually it seems to activate itself by itself.
Re: Not start driver automatically
It is started by a Windows registry entry for starting applications.
There is a shortcut in the start menu that shows how to stop (and start) it.
But as you point out, it will get restarted automagically (if you start an application that needs it).
If you don't want it to run, uninstall it.
