3ds Max viewport switching constantly
enzo_87
Re: 3ds Max viewport switching constantly
Post by enzo_87 »
Hi everyone,
same problem here on max 2021.
I tried the downgrade from 10.7.1 to the 10.6.0, but with those driver the mouse works fine in cinema 4d, but in my max don't even move around.
neither 10.6.3/4
10.6.9 moves around fine, but has the problem explained in this post.
all the setting for the mouse are the defautls one after the new install
carlitoscastellanos
Post by carlitoscastellanos »
Hi, where you able to fix this on max 2021? This is driving me crazy! i can't believe that 3D Connexion has not fixed this issue, this posts are super old and describe the same issue.
friendpicksd
Post by friendpicksd »
same issue here. :cry:
sdf
giozaha
Post by giozaha »
I dont believe that we cannot use our equipment one year now. This is unacceptable, I am really sad about your support
carlitoscastellanos
Yes it's ridiculous! Please help!!!
You may want to check the software released yesterday (v. 10.7.2) and available for download here.
KODO
Post by KODO »
Finally new version software in released, and seem to works!!
davidmarsh
Post by davidmarsh »
I observed the camera switches to angle however remains still with 3dsmax general camera. On the opposite hand, if I use vary physical camera, or 3dsmax bodily digital camera, the space mouse driver rotates my cameras and leaves them rotated when I choose any item on that viewport. It has emerge as impossible to paintings with the new driver. The beyond drivers' troubles had been greater viable.
rdk@live.co.uk
Post by rdk@live.co.uk »
Hi all, I think I found the possible issue.... Check to see if you have a "State Set" on the camera... solution: delete the Camera state set! 8)
garkbeda43
Post by garkbeda43 »
I rolled back to the previous drivers and works perfectly.
jantahu8
Post by jantahu8 »
jantahu8
Post by jantahu8 »
i can't believe that 3D Connexion has not fixed this issue, this posts are super old and describe the same issue. get-vidmateapp.com mobdro download
