Invalid File Found
gibson1
Invalid File Found
Post by gibson1 »
First time user of SpaceMouse. This happens whenever I go into the mouse Properties dialog for a new application that has never been configured for SpaceMouse. I goto Advanced Settings, and make a property change, like check a checkbox, and I immediately get a popup error message:
"Invalid File Found
{InvalidFileName} is invalid in 17.6.4. XML document must have a top level element."
This only happens once, since I suspect no .xml file has yet been created for this application.
Is this normal behavior? Because, as a new user, it seems unusual to me.
Using:
3DxWare 10 for Windows (64-bit)
10.6.4
Re: Invalid File Found
Hi gibson1,
does the file in that location exist? I assume that the location mentioned in the error message is C:\Program Files\3Dconnexion\3DxWare\3DxWinCore64\Cfg ?
Do you have an XML file with that name in your folder %APPDATA%\3Dconnexion\3DxWare\Cfg ?
Do you get the error message each time you start the driver (= when you log in)? Or each time you start AutoDesk Moldflow?
gibson1
Post by gibson1 »
Whenever I get that error message, I have no .xml files with that particular name in my roaming application folder.
But, they do get created afterwards, so no issues there. The message doesn't appear anywhere else.
I was just wondering, as this seems to be verbose debugging information that perhaps somebody forgot to turn off.
Hi gibson1,
is the path to the XML file in your error message pointing to your AppData\Roaming\3Dconnexion\... folder or to C:\Program Files\3Dconnexion\3DxWare\3DxWinCore64\Cfg?
gibson1
Post by gibson1 »
All .xml files are created in my roaming application folder, such as:
C:\Users\<username>\AppData\Roaming\3Dconnexion\3DxWare\Cfg\3DxTest.xml
gibson1
Post by gibson1 »
There's also a .xml file of the same name in the Program Files folder too:
C:\Program Files\3Dconnexion\3DxWare\3DxWinCore64\Cfg\3DxTest.xml
But, the two .xml files contain different data, and are different file sizes, so they're not the same.
gibson1
Post by gibson1 »
And if I delete the .xml file in the roaming appdata folder, I can recreate the "Invalid File Found" system tray popup error message again.
Hi gibson1,
thanks for the detailed information. We are tracking this issue with our internal bug number WIN-568. I will come back to you when I have new information.
I3art
Post by I3art »
I have the same error. Also when setting speed for a "new" application. Again every time I have rebooted my system.
Software verions:
3DxWare 10.6.6.3194
3DxWinCore: 17.6.6.17336
Device:
SpaceNavigator (FW: 3.18)
I3art
Post by I3art »
I might have solved it. Setting 3Dconnection Properties to "Run as Administrator" seems to help.
Hi I3art,
if you run the driver with admin privileges you very likely get in trouble when using it with your CAD applications.
I suggest you remove the existing settings to have a "clean" installation. Then you shouldn't see these errors anymore. See here how to remove existing user-specific settings.
mhoopes
Post by mhoopes »
I ran into that message when trying to edit %appdata%\3Dconnexion\3DxWare\Cfg\AdobeReader.xml. When I saved the file in notepad++, the notification came up in Windows 10, and the xml file disappeared!
I reset my settings as Uta described above, installed 10.6.5, ran notepad++ in admin mode. Don't know if those last two were necessary, but I wanted one-shot-one-kill, and it worked.
By the way, the reason I was editing my Adobe Reader configuration is that I've noticed that all I want is smooth vertical scrolling like I get with PDF docs in Google Chrome, using the mouse wheel emulation Rx axis. Up/down (Z) is much more awkward for doc scrolling.
I turned off all axes in 3DxWare (while Adobe Reader was the active app) except Rx, then changed the output of Rx to Z in the xml file:
<Axis>
          <Enabled>true</Enabled>
          <Input>
            <Min>-512</Min>
            <Max>511</Max>
          </Input>
          <Output>
          </Output>
        </Axis>
Michael Hoopes
mhoopes
Post by mhoopes »
I added the left-right scrolling action, too:
<Axis>
          <Input>
            <Min>-512</Min>
            <Max>511</Max>
          </Input>
          <Output>
          </Output>
        </Axis>
Michael Hoopes
