3DSMax 2020/21 Keeps switching back and forth to perspective view
nagboy
Post by nagboy » Thu Aug 06, 2020 12:17 am
This bug has persisted for so long now, and its such a huge bug, is it something with my setup or is something super wrong with the driver?
Using a standard SpaceMouse w/latest driver.
Ive made a screen capture how it looks like: https://youtu.be/nGx73B0_IK8
This bug is so destructive it actually renders the spacemouse more or less useless.
1. Its difficult to work when the screen is flicking like crazy.
2. Camera paths that are animated with the Spacemouse are not saved correctly. When you close 3DSmax and open it again the camera path is completely different. I have no idea how this can even happen, but its happened on multiple scenes and ive concluded that the only common factor is the spacemouse.
This bug has been around -and getting worse- for over a year now, is there any chance for a fix?
e.
Re: 3DSMax 2020/21 Keeps switching back and forth to perspective view
Post by UtaSH » Thu Aug 06, 2020 9:12 am
Hi nagboy,
which driver version do you have installed?
Piotreq91
Post by Piotreq91 » Mon Aug 10, 2020 1:09 am
I have this problem from very long time. The newest driver didn't repair this. My space mouse enterprise is not usable with any verision of 3ds max. I tested from 2017 to 2021(clear- without any other plugin). Additionaly in newer verision of drivers my 3ds max crashing nearly every time when I trying to change viewport using spacemouse button. Problem doesn't exist when I use standard keyboard.
cwdsnb
Post by cwdsnb » Tue Aug 11, 2020 3:38 am
I also have had this problem of viewport jumping between camera and perspective and managed to fix it by turning off 'auto' in rotation centre in advanced settings whilst running 3dsmax 2020/2021 (you have to do this per max version). I also set 3dsmax shade level to standard (previously used DX mode) as it reduced the glitchy viewport when moving about.
alexmarks3d
Post by alexmarks3d » Tue Aug 11, 2020 11:46 am
OMG this has been infuriating for so long... this seems to have worked. Although this behavior is sporadic, I hope it's not a coincidence.
Thanks a million!!! :D :D :D :D :D
Piotreq91
Post by Piotreq91 » Wed Aug 12, 2020 12:41 am
" hwdsb " Thank You a lot. Now is much better. I think that moderator should pin this post, because many users have this problem and can't find solution anywhere.
studiotetris
Post by studiotetris » Thu Aug 13, 2020 2:23 am
On July 3rd, I requested assistance to resolve this problem. After more than a month there is no solution, I write to the ticket without feedback ... escalation to the 3rd line without success ...
studiotetris
Post by studiotetris » Thu Aug 27, 2020 6:20 am
I update today 3dsmax to 2021.2 version but the problem remains the same.
Even using "stop driver" the problem persists ... to completely eliminate the error there is only the possibility to remove the drivers.
Is it possible to know if a solution is planned? Could it be tied to rtx video cards?
hughwyeth
Post by hughwyeth » Tue Sep 15, 2020 1:30 am
Thank you!
Is there a fix coming for this issue and the motion blur/smearing issue in max at all?
nushki
Post by nushki » Mon Oct 05, 2020 9:33 am
OMG! Thank you so much! I wasthinking about returning my mouse that I love but this problem made it impossible to use it.
!!!THERE HAS TO BE A FIX FOR THIS!!! PLEASE!!!
Post by UtaSH » Wed Oct 07, 2020 1:41 am
Hi all,
did you install the latest driver from Sept 15th? 3DxWare 10.7.0 is the current one.
studiotetris
Post by studiotetris » Mon Oct 19, 2020 10:07 pm
Yes, I try the 3dxWare 10.7.0 but:
- randomly the switching back ti perspective view return :shock:
- You have synchronized the camera view with the perspective view but the changing and flashing of the 3dsmax bottom right icon continues preventing other keyboard shortcuts :shock:
- Now, when I move the perspective view it automatically changes the focal range :shock:
3 months have passed since the appearance of this problem ... any news:?:
studiotetris
Post by studiotetris » Tue Oct 20, 2020 7:07 am
If you click on "menu" - "advance setting" - "rotation center" - "auto"the problem gets worse.
If you remove the problem it gets better ... I don't know if it can help.
Please HELP!
thad
Post by thad » Fri Oct 30, 2020 11:00 am
Yeap
I still have this same issue, camera keeps switching, I'm using max 2021.
studiotetris
Post by studiotetris » Tue Nov 17, 2020 11:59 pm
Some news?
