Silent Installs
cranston
Silent Installs
Post by cranston » Tue Sep 22, 2020 12:00 pm
In the past I would record a response file and deploy drivers using that. The newer (about 10.6.7+) installer is supposed to work similarly but it doesn't seem to be able to record anything using the switch SaveSettings=”c:\temp\3DxWareSettings.xml". I get an error at the end of the install telling me it could not write the XML file. It does install fine though, just not record the responses.
Has anyone been successful with the above method? Or do you just silent install each desired MSI?
-Brian
Re: Silent Installs
Post by ngomes » Wed Sep 23, 2020 1:13 am
Hi cranston,
Can you please recheck the exact command-line that you're using? I suspect you may have invalid characters in the path of the XML file (you have a curly ” double quote in your example) or the directory does not exist.
When running the installer to capture the installation settings, the command-line can be:
<executable file name> SaveSettings="c:\temp\3DxWareSettings.xml"
The "c:\temp\" directory must already exist before running the software.
To use the XML file in subsequent installations, use the "LoadSettings" command line option.
For a summary of the available commands and options, run the installer with the "/help" command.
