Spacepilot pro adding spacemouse moves to 3dsmax undo stack
For some reason my spacepilot pro adds a spacemouse move to the undo stack. This never used to happen and is very frustrating. Is there anything I can do to stop this?
Re: Spacepilot pro adding spacemouse moves to 3dsmax undo stack
Hello macspeedee,
can you please provide the driver version and your version of 3dsmax?
3DS max 2016 and 3DxWare 10.6.7.3198, 3DxWinCore 17.6.7.17382
I appreciate there is a new update 10.7.0 but am reluctant to do this as the last time I tried to update your driver it got stuck in an endless loop and I had to move over to windows 10 just to get it to work, so if you can assure me that updating will fix this and the other issues I have i.e. mouse stopping working when I clone an object in max and the viewport jumping all over the place when not in perspective view then it may not be worth the risk.
Im having the same issue in Max 2015 where the camera jumps all over the place in orthographic 2D views. and it does it in both 3DxWare64_v10-4-2_r2319 and 3DxWare64_v10-7-0_r3248
