Radial menu icons
Isarescu
Radial menu icons
Post by Isarescu » Thu Nov 19, 2020 10:57 am
After updating to the latest drivers, the radial menu icons dissapeared.
Is it a bug or this is the new look?
Re: Radial menu icons
Post by UtaSH » Fri Nov 20, 2020 5:28 am
Hi Isarescu,
this seem to be a bug.
Which application are you using? Did all icons disappear or just the application specific? Do you see the same issue with just one application or in all applications?
Isarescu
Post by Isarescu » Mon Nov 23, 2020 5:13 am
Sketchup 2020. Just the application specific.
Post by UtaSH » Mon Nov 23, 2020 10:01 am
That's odd. Try of deleting your user specific configuration for SketchUp solves the issue. You do that by deleting (or moving to another place) the file SketchUp.xml from your %APPDATA%\3Dconnexion\3DxWare\Cfg folder. (Usually "C:\Users\username\AppData\Roaming\3Dconnexion\3DxWare\Cfg\SketchUp.xml")
Isarescu
Post by Isarescu » Tue Nov 24, 2020 10:58 am
Did not solve the problem.
Post by UtaSH » Fri Nov 27, 2020 7:48 am
Hi Isarescu,
I recommend to contact our Technical Support Team. Once you got an email reply from the team you might want to send a video of the problem so that we can analyze it.
