Hi all,
This might be a real simple question but I can't see the solution and I did search for it.
For some reason I noticed today that when I press down the "1" button on my Spacemouse pro for more than a second there is a popup that shows which functions are assigned to all 4 bottons.
I assigned the control key to button 1 for Inventor so I can snap to degrees while ballooning a drawing, this means I hold it down for some seconds to manouvre the balloon in place.
It also looks like the function doesn't really work anymore when the popup is there.
Is there a way to turn this off?
Kind regards,
Aram.
Pop up when pressing down button1/2/3/4
Re: Pop up when pressing down button1/2/3/4
You can disable the On-Screen Display in our GUI (Buttons page). This also disables that LongPressButton functionality.
You will then be able to hold the button down and get a separate release when you release it.
Hi Jwick,
Fook me, that was so simple it's embarrassing....
Thanks man, sometimes the answer is right in front of you and you dont see it hahaha.
Kind regards,
Aram.
Kind regards,
Aram.
