Pop up when pressing down button1/2/3/4
Tranquill
Post by Tranquill »
Hi all,
This might be a real simple question but I can't see the solution and I did search for it.
For some reason I noticed today that when I press down the "1" button on my Spacemouse pro for more than a second there is a popup that shows which functions are assigned to all 4 bottons.
I assigned the control key to button 1 for Inventor so I can snap to degrees while ballooning a drawing, this means I hold it down for some seconds to manouvre the balloon in place.
It also looks like the function doesn't really work anymore when the popup is there.
Is there a way to turn this off?
Kind regards,
Aram.
Re: Pop up when pressing down button1/2/3/4
You can disable the On-Screen Display in our GUI (Buttons page). This also disables that LongPressButton functionality.
You will then be able to hold the button down and get a separate release when you release it.
Tranquill
Post by Tranquill »
Hi Jwick,
Fook me, that was so simple it's embarrassing.... :oops:
Thanks man, sometimes the answer is right in front of you and you dont see it hahaha.
Kind regards,
Aram.
