Switch buttons 90 degrees, spacemouse
blatherdough
Post by blatherdough » Fri Dec 04, 2020 1:55 am
I've got the 2 button device.
I want to use the buttons most convenient, and rotate the device 90degrees to the right (clockwise). The wire is on the right side of the spacemouse.
What do I need to change exactly in the .xml to achieve this? I've tried fiddling around some of the HID output rules, but it's always a mess using the mouse.
After a change in the Base.xml file like mention here: https://forum.3dconnexion.com/viewtopic ... ees#p76740
  • I close all the 3dconnexion stuff in the windows 10 task manager,
  • Double click the 3DxNS_Local
  • Open Blender
  • and test
If it doesn't work, I repeat the above steps. So walk me through it, and explain it to me like I'm a 10 year old baboon because I don't get it.
If I get a reply in a few days, I'm happy. If not, happy new year! < this is sarcasm off course. I do think the support is very, very slow with responding. Nothing personal.
I'm still waiting on a reply about a possible defect mouse I bought a few weeks ago: CASE:115546 and CASE:114002 (this one doesn't matter anymore, I switched to Windows) took you guys a few months to answer. Yes, I switched to windows because of this problem.
