I'm setting up my SpacePilot Pro anew and I need a copy of KeyboardWASDTemplate.xml . Can anyone tell me where I can get a copy.
Thanks.
Re: KeyboardWASDTemplate.xml
It should be in the same place it usually is: <ProgramFiles>/3Dconnexion/3DxWare/3DxWinCore/Cfg/KeyboardWASDTemplate.xml.
The template import mechanism no longer exists. You have to manually copy the contents of that file to an application-specific cfg.
I have an example for you. I wrote this profile for Baldurs Gate 3.
I also use tab Z Axis to hit Y (german keyboard layout) what will center my camera view.
<?xml version="1.0" encoding="utf-8"?>
(c) Copyright 3Dconnexion. All rights reserved.
$Revision: 17343 $
<AppCfg xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" Default="false" CfgFormatVersion="1.3" ThisFileVersion="1.12">
<AppInfo>
<Signature>
<Name>Baldur's Gate 3</Name>
<ExecutableName>bg3_dx11.exe</ExecutableName>
</Signature>
<Options />
</AppInfo>
<CfgProperties>
<ID>ID_Baldur's Gate 3</ID>
<InheritsFromID>ID_Default_KMJ_Cfg</InheritsFromID>
</CfgProperties>
<MacroTable>
<MacroEntry>
<ID>1</ID>
<KeyStroke>
<Key>1E</Key>
</KeyStroke>
</MacroEntry>
<MacroEntry>
<ID>2</ID>
<KeyStroke>
<Key>1F</Key>
</KeyStroke>
</MacroEntry>
<MacroEntry>
<ID>3</ID>
<KeyStroke>
<Key>20</Key>
</KeyStroke>
</MacroEntry>
<MacroEntry>
<ID>4</ID>
<KeyStroke>
<Key>21</Key>
</KeyStroke>
</MacroEntry>
<MacroEntry>
<ID>M</ID>
<KeyStroke>
<Key>10</Key>
</KeyStroke>
</MacroEntry>
<MacroEntry>
<ID>X</ID>
<KeyStroke>
<Key>1B</Key>
</KeyStroke>
</MacroEntry>
<MacroEntry>
<ID>B</ID>
<KeyStroke>
<Key>5</Key>
</KeyStroke>
</MacroEntry>
<MacroEntry>
<ID>T</ID>
<KeyStroke>
<Key>17</Key>
</KeyStroke>
</MacroEntry>
<MacroEntry>
<ID>I</ID>
<KeyStroke>
<Key>C</Key>
</KeyStroke>
</MacroEntry>
<MacroEntry>
<ID>C</ID>
<KeyStroke>
<Key>6</Key>
</KeyStroke>
</MacroEntry>
</MacroTable>
<Devices>
<Device>
<ID>ID_ProductID_C631</ID>
<AxisFilter>None</AxisFilter>
<CurrentAxisBank>Default</CurrentAxisBank>
<AxisBank Default="true">
<ID>Default</ID>
<Name>STR_DEFAULT_BANK</Name>
<Axis>
<Enabled>true</Enabled>
<Input>
<Min>0</Min>
<Max>511</Max>
<Deadband>50</Deadband>
</Input>
<Output>
<RepeatStyle>PressAndHold</RepeatStyle>
<KeyStroke>
<Key>07</Key>
</KeyStroke>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>0</Max>
</Input>
<Output>
<KeyStroke>
<Key>04</Key>
</KeyStroke>
</Output>
</Axis>
<Axis>
<Input>
<Min>0</Min>
<Max>511</Max>
</Input>
<Output>
<KeyStroke>
<Key>16</Key>
</KeyStroke>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>0</Max>
</Input>
<Output>
<KeyStroke>
<Key>1A</Key>
</KeyStroke>
</Output>
</Axis>
<Axis>
<Input>
<Min>0</Min>
<Max>511</Max>
<Deadband>200</Deadband>
</Input>
<Output>
<KeyStroke>
<Key>1B</Key>
</KeyStroke>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>0</Max>
</Input>
<Output>
<KeyStroke>
<Key>1D</Key>
</KeyStroke>
</Output>
</Axis>
<Axis>
<Enabled>false</Enabled>
<Input>
<Min>-512</Min>
<Max>511</Max>
<Deadband>0</Deadband>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>0</Min>
<Max>511</Max>
</Input>
<Output>
<KeyStroke>
<Key>14</Key>
</KeyStroke>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>0</Max>
</Input>
<Output>
<KeyStroke>
<Key>08</Key>
</KeyStroke>
</Output>
</Axis>
</AxisBank>
<ButtonBank Default="true">
<ID>Default</ID>
<Button>
<Input>
<ActionID>HIDButton_13</ActionID>
</Input>
<Output>
<ActionID>1</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_14</ActionID>
</Input>
<Output>
<ActionID>2</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_15</ActionID>
</Input>
<Output>
<ActionID>3</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_16</ActionID>
</Input>
<Output>
<ActionID>4</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_2</ActionID>
</Input>
<Output>
<ActionID>M</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_27</ActionID>
</Input>
<Output>
<ActionID>X</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_9</ActionID>
</Input>
<Output>
<ActionID>B</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_3</ActionID>
</Input>
<Output>
<ActionID>T</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_5</ActionID>
</Input>
<Output>
<ActionID>I</ActionID>
</Output>
</Button>
<Button>
<Input>
<ActionID>HIDButton_6</ActionID>
</Input>
<Output>
<ActionID>C</ActionID>
</Output>
</Button>
</ButtonBank>
</Device>
</Devices>
<AuthorInfo>
<DriverVersion>17.7.0.17687</DriverVersion>
<LastChange>
<Tool>3DxSmartUI.exe</Tool>
<Version>1.2.20251.17614</Version>
<Date>11/10/2020 3:21:34 PM UTC</Date>
<User>mschenkbier</User>
</LastChange>
</AuthorInfo>
</AppCfg>
