Greetings,
Is the SpaceMouse Pro latest driver compatible with Autocad 2021.
I can only zoom and pan within Autocad 2021.
I will appreciate any prompt piece of advice.
Thank you in advance.
SpaceMouse Pro Autocad 2021
Re: SpaceMouse Pro Autocad 2021
Call out the 3Dconnexion Properties panel by hitting the MENU key on your spacemouse pro, then click the Advanced Settings button to see if the axis control is active or not.
