Hey,
I would like to report problems with the "Rotation center manually" function in 3dsmax 2021-2022.
This feature worked correctly with older drivers. Unfortunately, it is dead since the last updates.
Nothing happens when I press ctrl + middle mouse button.
The blue cross remains in the center of the stage and does not react to attempts to change position.
This problem is global and has also been confirmed with other users of the device.
What am I using:
- Space Pilot Pro / driver 10.7.2.3314
- windows 10 (current updates)
- 3dsmax 2018-2022 (current updates)
best regards
Re: Rotation center manually
Same situation for me.
Lack of this function decreases the way we can navigate in viewport.
Main function this device was created for.
Hi there,
yes, I have the same problem with my SpaceMouse Pro.
The latest working driver is this one 3DxWare64_v10-5-6_r2771 for 3dx max 2018.
Rotation center with newest drivers doesn`t.
It's really annoying that I can't use newer versions of 3ds max. Without a working rotation center, the device becomes useless to me.
Please fix it ASAP!
Please fix it ASAP!
Hi All,
Thanks for the prompt replies! I was checking to see if we have a similar bug on our end for Rotation Center but nothing similar to your description
I would highly recommend to create a technical case in order to generate some log files and possibly record a short video showing the issue
Please open a technical case here https://3dconnexion.com/support-request/login/
Regards,
Abdul. A
Regards,
Abdul. A
