AutoCAD 2020 button and radial menu setup
ginkgoguy
Post by ginkgoguy »
Not sure how to access the set up of the mouse buttons or the radial menu.
thanks,
James
aalsalihi
Re: AutoCAD 2020 button and radial menu setup
Post by aalsalihi »
Hi James,
You can access these in our UI by making sure our settings window is detecting AutoCad
- Open AutoCad
- Open 3Dconnexion Home
- Click on Settings
- Make sure its showing AutoCad on the top of our settings window
- Click on Buttons
- Beside each button there's a right arrow ">", click on the ">" to display the folders. You should see a possible AutoCad folder with some generated functions
- One of the folders in the list is Radial Menu
- Click on Radial Menu folder, this can allow you to Create New radial menu or use existing once etc
Regards,
Abdul. A
