Need a PCB for the Spacenavigator
tollerteppich
Post by tollerteppich »
Hello Together
I have a corosion Problem on the PCB from my Spacenavigator and i search for Used Spacenavigators as Doner (with mechanical problems) or a NEw PCB
I Paralell try to repair the corrodet wires on the PCB with 0.2mm wire. i must also desoldering thhe IC. wish me luck that i find all disconections.
The problem is that the trouthhols particular eated away from the acidic solution under the PCB.
PLS Guys looked at your trash bin for old spacenavigators :D
I Want to repair for our nature !!!
Alexander
tollerteppich
Re: Need a PCB for the Spacenavigator
My repair was successful, but it is certainly not permanent, so I'm still looking for a replacement circuit board.
here are a few more photos of the repair.
tollerteppich
