Folks can someone point me in the right direction. I have Photoshop 2020. When I installed 10.7.3 of 3Dconexxion SW no Plugin was installed. Found instruction to extract and run the 3DxPhotoshop.msi from the install exe using &z. Did this and installed it. This then installed the 3DxPhotoshop_CC2017.8li file in the Adobe Plugin Folder.
Using Photo shop pan works fine but the forward and back movements do not zoom they pan up and down. The same as the Up and Down action. I have checked the control panel setting as they look fine. Pan and Zoom are both enabled. Tried swapping Zoom to up and down , same result.
So no zoom what ever I do. Please note and I zoomed in so pic is bigger that display area so I can check pan and zoom.
Any help greatly appreciated
Photoshop 2020 Zoom not working
Kings regards
plug_it_in
plug_it_in
