Any guides or notes on the XML cfg out there?
nirurin
Post by nirurin »
Trying to put together my own xml file, as the gui is... shockingly bad for customisations. Especially considering there's example files for joystick, WASD and keyboard layouts in the cfg folder, but nothing that actually lets you use them directly...
Anyway, doing it myself, but there seems to be zero documentation out there, so I'm looking for some help!
I've figured out that keystrokes are done using the (I assume its hex-based) code for each keyboard key, so I can figure that part out. And I can figure out the different axis as well. But -
1. What is V3DK_1 and V3DK_ROTATE? I thought maybe it was a button, but not sure where the rotate comes from (I don't think it's the actual rotation of the spacemouse, as that's an axis, I assume its the Rz axis?) So not sure what the V3DKs are.
2. Is it possible to set an 'output' to being multiple keys/buttons at the same time? (I'm currently trying to make pan-right become "hold spacebar and move mouse right", is that's at all possible?)
Really appreciate any help I can get with this!!
