Disable Mouse Wheel Doubleclick
3d-labor.de
Post by 3d-labor.de »
How to disable the mouse wheel doubleclick. As my CAD Mouse is about 8 to 10 years old it often happens accidentially, that PAN with pressed mouse wheel in AutoCAD leads to a "zoom all" command. So it would be great if there would be a way to disable the double click of the mouse wheel. I dont need this feature at all.
aalsalihi
Re: Disable Mouse Wheel Doubleclick
Post by aalsalihi »
Hi 3d-labor.de,
You can try disabling the wheel button in which will allow you to do just normal scrolling
- Open 3Dconnexion Home
- Click on Settings
- Make sure the application is detected on the top of our setting window
- Click on Buttons
- Beside the Wheel button, there's a right arrow ">" click on it and search for Disable
- Assign it then test it
Regards,
Abdul. A
