Enterprise does not detect function in 3D Experience
JanStr
Post by JanStr »
My Enterprise does not detect function in 3D Experience. When I open CAD and the utility software for 3DConnexion, I do not anything under 3DExperience/Part Design (or any other application). How should I solve this?
With regards,
Jan
luping
Re: Enterprise does not detect function in 3D Experience
Post by luping »
3DExperience version?
3DxWare driver version?
Most probably is that 3DExperience is partially supported.
luping
Post by luping »
By the way, you should check out the submenu of 3DEXPERIENCE in the fly-out menu of 3DxWare panel command mapping, if your version of 3DEXPERIENCE is supported.
aalsalihi
Post by aalsalihi »
Hi JanStr,
For 3D Experience, we only have support for navigation in which the display for part/assembly etc won't be showing within our UI as its not supported.
Also, if you talking about 3D Experience Solidworks connected then its not supported at the moment.
Regards,
Abdul. A
