Bad behavior with current driver when using Enscape for Sketchup and Revit
Walk mode in Enscape no longer works with the current driver. As soon as the mouse is moved, it is switched to fly mode.
Please fix it as soon as possible.
Otherwise we will be forced to dispose of all 3D mice!
Please also see the Enscape Forum: https://forum.enscape3d.com/index.php?t ... se-issues/
Thanks very much !
Kind Regards, Bernhard
Re: Bad behavior with current driver when using Enscape for Sketchup and Revit
Simple, downgrade your driver to a previous working version.
@ luping:
older driver do not support newer software (ex. Revit 2022, Sketchup 2021).
For this reason it is not possible to use them.
Kind regards,
Bernhard
Kind regards,
Bernhard
Quote my own words
and plus: or downgrade your licensed applications if possible.Simple, downgrade your driver to a previous working version.
