Photoshop CC (23.x) not working with SM?
Dutchottie
Post by Dutchottie »
My current version of Photoshop CC (23.4.2) does not accept any of the supplied plugins (3DxWare 10.8.8 ).
Is this correct? How should I otherwise install the plugin?
Cheers,
MArco
Re: Photoshop CC (23.x) not working with SM?
Go to the application installation directory and check if you can find the file "3DxPhotoshop_CC2017.8li" in the "Plug-ins" folder. If the file is missing, copy it from the driver installation (normally found at C:\Program Files\3Dconnexion\3DxWare 10\3DxPhotoshop).
We will fix this in the next driver release.
Dutchottie
Cheers! That did it.
I hope you'll manage to add zooming to the controls too. That would be nice.
Plus ofc a bunch of commands to program the buttons :-)
Thanks again.
Dutchottie wrote: Tue Sep 06, 2022 4:39 am I hope you'll manage to add zooming to the controls too.
Not sure I follow. We already have zoom support: if you move the SpaceMouse sensor cap back/forward it will zoom in/out along the direction indicated by the mouse pointer.
Dutchottie
Ah, so it is supposed to zoom :-) only it doesn't!
Didn't touch the settings. Panning works fine, but zooming...
Dutchottie wrote: Wed Sep 07, 2022 1:44 am Panning works fine, but zooming...
Did you assign a keyboard shortcut to the File > Automate > 3DxPhotoshop menu item?
Dutchottie
Hi again!
Yes I did. I opted for ctrl-F12. But whether I press that or not, nothing special happens. My Space Mouse still only pans the image no matter what motion I apply to it.
Is there something special I need to do with the assignment of the key shortcut (I did restart PS)?
I am presuming I only have to press the shortcut key once to activate the 3DxPhotoshop add-on?
Thanks for your help so far!
Marco
Dutchottie wrote: Wed Sep 07, 2022 6:11 am I am presuming I only have to press the shortcut key once to activate the 3DxPhotoshop add-on?
No need to press the shortcut. It's only meant to be used internally by the plugin.
Zooming is expected to work. Check the "Advanced Settings" panel in 3Dconnexion Properties (ensure you're editing the configuration for Photoshop) to see all motion axes are enabled. You did mention that no settings were changed but perhaps something got flipped inadvertently.
Installer support for Photoshop desktop 2022 was added in v. 10.8.9 of 3DxWare 10.
The software can be downloaded from here.
ngomes wrote: Mon Oct 03, 2022 12:02 pm Installer support for Photoshop desktop 2022 was added in v. 10.8.9 of 3DxWare 10.
No release notes?
luping wrote: Mon Oct 03, 2022 9:04 pm No release notes?
The release notes document has been added to the download page. Our apologies for the delay.
ngomes wrote: Tue Oct 04, 2022 12:20 am
So much has been done to improve 3DxWare for end users, thank you!
