Cinema 4D rotating camera
mfred
Post by mfred »
normally you use alt+mouse to rotate the point of view of the camera. doing this, the point of view rotates around the point where the cursor is. that way its very easy to rotate around one point/object in the scene.
using the spacemouse it seems that the center point of rotation always is the center of the view port. is it possible to change that? having a hard time doing a clean rotation around an object i.e.
