Driver 3Dconnexion SpaceMouse Entreprise for REVIT 2023
lcoqueret
Post by lcoqueret »
Do you know if we will have the driver 3Dconnexion SpaceMouse Enterprise for REVIT 2023 and when ?
Best Regards,
Laurent
DavidV
Re: Driver 3Dconnexion SpaceMouse Entreprise for REVIT 2023
Post by DavidV »
Best Regards,
Laurent
Our current driver 10.8.11, does support REVIT 2023 and Enterprise Navigation.
Are there other issues you may be having?
Alakelele
Post by Alakelele »
The issues are probably the same as in 2022, meaning that the Center Tool needs to have an auto functionality. Wished behavior: Select an element once, center tool activates with this selection and then shuts down, IF another rotation point is desired, only activate the center tool once, select the object where the rotation point, the center tool activates, the center tool shuts down after that automatically.
Thanks in advance
