space navigator: how to invert rotation/tilt axis?
Hello, i just installed the newest version of the drivers, coming from a very old one (like 6.something...). I'm using the space navigator with creo 2.0. Now i have a problem... with the older software, changing the zoom direction was also changing the rotation axis of the mouse with the tilting one. Pratically, now when i rotate the mouse, the object on screen will tilt left and right, i need (because i ever used it this way and i find more confortable) that with thi movement of the mouse, the object on screen will rotate on the axis perpendicular to the screen, and tilting left and right the mouse will tilt the object the same way.
How is that possible? With the old software version i just need to change the type of the zoom...
Thanks in advance to everyone!
Andrea
Andrea
Re: space navigator: how to invert rotation/tilt axis?
Hello Andrea,
Yes, we changed this behavior for the new driver. We had people complain that they didn't want to change the rotation direction when the GUI said it was just changing the zoom direction. So far, just as many people complain about it this way--exactly the opposite group. We can't win
You can set the axes any way you want, but you can't use the GUI. The GUI only does it "its way".
You have to edit the Cfg file for your application (Creo). The file is ProE.xml.
Change the zoom direction in the GUI, so you have a file that you can edit.
That file will be in %appdata%\3dconnexion\3dxware\Cfg. (ProE.xml).
You can use any XML editor, even notepad.
Find the section that contains <Name>SpaceNavigator</Name>
Under this you will see some <Axis> entries. Something like this:
The above sample indicates that each Rx, Ry, Rz axis Input is set to the same Output. If you want the Ry Input to generate an Rz Output, change the Output/ActionID from HIDMultiAxis_Ry to HIDMultiAxis_Rz. Make sure to make he cooresponding change to the Rz Axis (HIDMultiAxis_Rz->HIDMultiAxis_Ry).
You can also reverse the direction of the Axis by changing <Reversed> from False to True.
<Axis>
<Enabled>true</Enabled>
<Input>
<Min>-512</Min>
<Max>511</Max>
<Deadband>0</Deadband>
</Input>
<Output>
<Reversed>False</Reversed>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
<Axis>
<Input>
<Min>-512</Min>
<Max>511</Max>
</Input>
<Output>
</Output>
</Axis>
Thanks so much for your prompt reply! So now i will try this way, i just have to hunderstand how to do, because the xml file is located in a folder where i cannot write, unfortunately i'm not administrator on my machine due to company polytics.
Thanks again!
Andrea
Thanks again!
Andrea
%appdata% is a directory for your personal files. It is under your username and it roams with you when you login to different machines (in an Active Directory environment). You should be able to edit it.
Don't try to edit the file under Program Files.
In fact, just after have posted my last reply, i've noticed that i was looking at the wrong file
Few minutes ago i finished the configuration and everything is working well!
Thanks a lot for your cooperation, have a nice day!
Andrea
Andrea
hi, im trying to do this and i dont see any R axis in my file
im editing the cube3d demo file.
The axis isn't in the user file unless you've made some change to it. You can copy it from the default file, or, much easier, just make some change to the axis in the GUI. It will then be written into your appdata file.smoke wrote:hi, im trying to do this and i dont see any R axis in my file
got it, thank you!jwick wrote:The axis isn't in the user file unless you've made some change to it. You can copy it from the default file, or, much easier, just make some change to the axis in the GUI. It will then be written into your appdata file.smoke wrote:hi, im trying to do this and i dont see any R axis in my file
more questions...
is there a way to make this change to be defaulted to every application?
without having to change every specific xml file?
you mentioned a default file... will this be the one that sets a system wide standard?
lastly... where is it located?
thanks
thanks
The default files are in a read-only directory--typically, C:\Program Files\3Dconnexion\3DxWare\3DxWinCore64\Cfg.
If you change the Base.xml file, most of your applications will switch (unless there are Axis entries in the app-specific files).
thank you, it worked!jwick wrote:The default files are in a read-only directory--typically, C:\Program Files\3Dconnexion\3DxWare\3DxWinCore64\Cfg.
if anybody else wants to do the same:
close the 3dconnexion software/driver
copy that base.xml file to your desktop
open it with notepad, ctrl+F and type in your model(mine was spacenavigator).
look for input "Ry" and change its output to "Rz". and the same for input "Rz" to output "Ry".
save it, and copy the file back to the original location and overwrite.
start up the 3dconnexion software/driver
test it out and reverse the axis in the 3dconnexion software as needed.
Hi I also want to invert my Spin and Roll functions for application Solid Edge.
My SolidEdge.xml file does not contain any Ry or Rz strings, the text is more like this:
<AxisFilter>Dominant</AxisFilter><Axis><Enabled>true</Enabled><Input><ActionID>HIDMultiAxis_Z</ActionID><Min>-512</Min><Max>511</Max></Input><Output><ActionID>HIDMultiAxis_Z</ActionID><Reversed>false</Reversed></Output></Axis><Axis><Enabled>true</Enabled><Input><ActionID>HIDMultiAxis_X</ActionID><Min>-512</Min><Max>511</Max></Input><Output><ActionID>HIDMultiAxis_X</ActionID><Reversed>false</Reversed><RepeatStyle>Auto</RepeatStyle></Output></Axis><Axis><Enabled>true</Enabled><Input><ActionID>HIDMultiAxis_Y</ActionID><Min>-512</Min><Max>511</Max></Input><Output><ActionID>HIDMultiAxis_Y</ActionID><Reversed>false</Reversed><RepeatStyle>Auto</RepeatStyle></Output></Axis></Device>
</Devices>
</AppCfg>
Please direct me as to what text strings need to be changed?
Thanks.
</Devices>
</AppCfg>
Thanks.
Add the Axes, as shown here
Hey all, im trying to invert the rotation/tilt for solidworks. (http://i.imgur.com/uG7d2Vf.png)
Ive tried to change the code using wordpad but its a mess (http://i.imgur.com/uG7d2Vf.png)
Does anyone have an existing file for 10.0.22 SolidWorks XML document that has this already inverted so i could just download it and paste it in my C:\Users\tholden\AppData\Roaming\3Dconnexion\3DxWare\Cfg folder?
Or is there any other easy way to get this to work?
Thanks much!!!!!!
Thanks much!!!!!!
Meant to say
Ive tried to change the code using wordpad but its a mess <EDIT:> (http://i.imgur.com/uG7d2Vf.png)
