3dxware 10 - settings location
spainman
Post by spainman »
where are the user settings (personal button configurations, sensitivity etc.) stored in Win7 x64? I want to backup the settings.
I assume it's in .../user/AppData/ but then there are different 3dconnexion folders that might belong to a pre V10 installation so it seems better to ask...
Thanks in advance.
Fred
Re: 3dxware 10 - settings location
Post by Fred »
Hope this helps:
C:\Users\username\AppData\Roaming\3Dconnexion\3Dxware\Cfg 3Dxware 10 driver.
C:\Users\username\AppData\Roaming\3Dconnexion\3Dxware\Profiles is the 3.17.8 driver
spainman
Post by spainman »
I assume you mean C:\Users\username\AppData\Roaming\3Dconnexion\3DxWare\Cfg, right?
What about the stuff in ...\AppData\Local\3Dconnexion\ ?
Still quite confusing. What happens if I simply delete all 3Dconnexion folders in AppData? Will all needed stuff be recreated when the Software is restarted or do I need to reinstall? I don't mind loosing the current settings by doing so. I just want a clean start for subsequent backups and settings syncing between machines.
Fred
Post by Fred »
This is what you should do for the clean install:
http://www.3dconnexion.com/faq/1100
spainman
Post by spainman »
Done. Thank you.
