Hello all!
I have an older Cadman controller. We just got Cimatron E7.1 software, which in my 25+years in the trade is the best software available for the design and production of plastic injection molds, bar none. My problem is my Cadman pans and zooms correctly, but the rotations are backwards and make me sea sick. I spoke to another Cimatron user and he has the same problem. Is there a fix for this?
Thank You!
Problems with Cimatron E7.1
Hi gforrest,
please specify what version of the 3DxSoftware do you use.
What operating system do you have installed, whith which SP?
Has your device a serial or a USB connector?
Hi gforrest,
please read the post of jwick, it could solve your problem:
viewtopic.php?p=595#595
If this wouldn't help you, please contact the support from Cimatron, because they implemented the support for our devices in the application.
In our new driver, which are offered with our new devices (or you can just download it from our homepage), is implemented a solution to change the direction of rotation and movement (pan), however this driver doesn't support Cadman any more.
