Editor to assign custom icons
Wreubzaet
Post by Wreubzaet » Tue Oct 17, 2017 4:23 am
I'd like to share with you two requests for improvement from my experience with the 3DxWare drivers in Creo Parametric with the SpaceMouse Enterprise.
1) Custom mapkey icons are not displayed on the display, only the default (smiley) icon. I'd love to to see this implemented, since I have made many custom mapkey icons. This might be a Creo specific issue?
This leads me to my main request:
2) Please implement some kind of menu/editor to assign a custom icon to a command or macro, which can be used with any software.
This would also work as a workaround for the first item. A radial menu with 8 identical icons simply does not improve usability ...
I tried setting up custom icons myself by using the instructions in other forum posts, but so far without success. I'm missing clear instructions on:
- which files
- in which locations must be edited
- what sections of these files must be edited and
- what the correct syntax is
For the time being clear instructions on how to set this up will do, but implementation of this functionality in the driver would be great.
Fyuzinfected
Re: Editor to assign custom icons
Post by Fyuzinfected » Wed Jan 03, 2018 5:00 pm
Hi!
Is there any news about this?
Greetings from Portugal.
Fábio Martins
nwink
Post by nwink » Thu Jan 11, 2018 1:31 pm
I to am looking for information regarding setting custom icons (.png) to Macros I have created in Microstation.
Has there been any updates to this problem? I was trying to piece together information given on other posts but they aren't crystal clear and I don't want to mess up my mouse.
Great tool, but could be so much more useful with a custom icon generator or instructions to do so. Had a lot of people in the office interested in the device, but a lot were turned off because of this hiccup.
AxeGunKnife
Post by AxeGunKnife » Thu Jan 18, 2018 2:50 pm
I, too, could not customize the icons in the radial menu. I also asked the developer questions in other branches. But .... they did not answer me.
dylanren99
Post by dylanren99 » Tue Jan 23, 2018 9:17 am
Would love this to be a official supported option, tried going into the code and coding it but not much luck.
sstephenson1x
Post by sstephenson1x » Wed Feb 21, 2018 12:17 pm
A short note to support this request for an editor. It's more useful to see within the radial menu: hide, show, or delete, rather than Keystroke Control+b, Keystroke +.... The ... is meaningless and the menu is no longer meaningful.
MakerinTraining
Post by MakerinTraining » Fri Apr 13, 2018 12:21 pm
I am also interested in this feature, or at least a clear post detailing how to do it manually. . .
KantC
Post by KantC » Mon Jul 30, 2018 2:52 pm
I have the same interest especially for radial menu.
For 8 secments that only show generic icon with a split second of macro name is very difficulty to use. When having multiple applications set with different set of macro, it is almost counter productive to use this high potential interface.
Hope the hear good news from 3dconnextion soon.
In the mean time, I need to return what I purchased.
Good product, good material , good potential.
Thank you.
mug3d
Post by mug3d » Mon Oct 22, 2018 6:42 am
+1
For me that's "top priority"
mug3d
Post by mug3d » Mon Oct 22, 2018 6:45 am
A short video or gif, YouTube wiuld be nice
Fyuzinfected
Post by Fyuzinfected » Sat Nov 17, 2018 11:02 am
In the meantime already released version 10.5.11 and there is no news about this subject.
It is very sad to know that I have paid a high amount for this equipment with such useless functions.
Fábio Martins
JDI
Post by JDI » Sat Feb 02, 2019 9:03 am
I want this feature! And a way for me to customize the knob function. Why would you work at making specific programs usable yourself? The Adobe CC support hasn't worked for me even once. Let me map my own functions to the knob. It would be such a better and more versatile product.
npacholko
Post by npacholko » Mon Mar 04, 2019 3:47 pm
I would love to have this feature as well. I use a Spacemouse both at work and at home, and my fellow employees who use it agree.
Wreubzaet
Post by Wreubzaet » Fri Mar 15, 2019 12:56 pm
Just wanted to let oy know I still -really- miss the an editor or manual to use custom icons on the radial menus... Developers please implement this!
Wreubzaet
Post by Wreubzaet » Mon Mar 18, 2019 2:19 pm
Hello everyone. As a workaround until hopefully an editor to assign custom icons will be implemented, I have been trying to figure out how to replace the default Creo mapkey icons in the radial menus by my own icons, i.e. the custom icons I made which are displayed in Creo menus. I have all the icons as separate .png files in a folder on my PC.
I found that every time I run Creo several .XML files are created in g:\AppData\Local\3Dconnexion\3DxWare\Cfg\Ext\ e.g.
5224.96752288.commands.xml
5224.96752288.images.xml
5224.96752288.settings.xml
The images.xml is the only file I could find which contains references to the used icons. When I replace the icon reference by the correct .png file reference the radial menu shows the correct icon. For example I replaced:
<AppCmdID>ProMacro xa</AppCmdID><Image Type="File"><File>C:/Program Files/3Dconnexion/3DxWare/3DxWinCore64/Cfg/Images/STR_PROE/Creo-Mapkey.png</File>
by:
<AppCmdID>ProMacro xa</AppCmdID><Image Type="File"><File>e:/PTC/config/Mapkey_Icons/Cross section A_32.png</File>
So far so good...
However, these .xml files are deleted when closing Creo and recreated upon each program start (with a different number in the filename). So the driver seems to pull the menu information from somewhere else to recreate these files. I suspect these are created on the fly from the current Creo config? Can anyone confirm this? If this is the case then probably the only way to get the correct icons is to replace the .xml file by a backup with the correct icons after each program start...
Or is the icon information pulled from somewhere else where I can safely edit it without it getting overwritten every time?
Many thanks in advance for any help!
