SpaceMouse Wireless/3DxWare Suggested Enhansements
borland
Post by borland » Sun Nov 19, 2017 9:59 am
1. Problem: When charging by USB cable, the 3DxWare v10.5.3 Control Center only says "Charging". Recommend: Adding State of Charge in "Percent Complete"; this to allow user to judge how much longer charging is necessary. Comments: When charging, battery icon graphic is too small to judge percent charged. When using SpaceMouse wirelessly, the control center does provide "Percent" state of charge so user is able to judge when recharging may be necessary.
2. Problem: There is no way to re-configure pan and zoom directions for orientation of SpaceMouse with respect to user. Recommend: Adding option in Control Center to allow repositioning orientation of SpaceMouse in 90 degree increments. Comments: 3DxWare v10.5.3 driver software assumes user will only use in one position. If SpaceMouse is positioned 180 degrees, pan and zoom moves virtual objects in reverse directions.
