Fusion 360 "Constrained Orbit" / "Lock Horizon"
StephenM
Post by StephenM » Fri Jan 24, 2020 10:50 pm
Constrained orbit is the default setting in Fusion 360 when using the standard mouse, keeping up facing up, and the horizontal horizontal. This is the preferred way to navigate, with 5 degrees of freedom.
However, it doesn't work with the Spacemouse.
Turning off one or two of the rotational axes in 3DConnexion Properties does not achieve this.
Please help.
In Solidworks, this was possible using "Rotate about Scene Floor".
Please implement this important fix for Fusion 360.
Re: Fusion 360 "Constrained Orbit" / "Lock Horizon"
Post by UtaSH » Tue Feb 04, 2020 5:15 am
Hi StephenM,
the support for the SpaceMouse in Fusion360 was integrated by Autodesk. Please contact their Support Team to let them know that the "Lock Horizon" would be an imported feature to add.
